Author Topic: 500KHz peak detector  (Read 947 times)
Offline ricko_ukTopic starter
« on: February 26, 2020, 06:19:48 pm »
I have to make a peak detector of up to 500KHz. Using some of the classic configurations require a more expensive (high speed high slew rate op-amps).
I have come across a comparator-type peak detector below but it start introducing error at 100KHz
Any other suggestions for higher frequencies up to 500KHz? Or at the absolute minimum 250KHz?
Many thanks :)
« Last Edit: February 26, 2020, 11:44:36 pm by ricko_uk »
Offline graybeard
  • Consulting III-V RF/mixed signal/device engineer
    • Chris Grossman
Re: 500KHz peak detector
« Reply #1 on: February 27, 2020, 12:02:58 am »
what is the range of signal amplitudes?
do you need both positive and negative peaks?
what are the source and load impedances?
you need to define your requirements more completely
« Last Edit: February 27, 2020, 12:05:00 am by graybeard »
Offline vk6zgo
« Reply #2 on: February 27, 2020, 12:23:56 am »
An old style "peak & hold" detector can work up into UHF, but may have limitations, in that very fast peaks in the midst of a lower frequency signal may be missed.
If you need to detect rarely occurring transients, you are pretty much stuck with doing it digitally, & will need a very high sample rate, plus a lot of memory.
If the transients you want to see are very infrequent, maybe the device could check what it has "seen" for a set previous time, flag that as "no transient found", empty & re-use the memory.
Offline Circlotron
« Reply #3 on: February 27, 2020, 12:30:45 am »
Precision AM detector?
I have a circuit at home I'll post later.
The following users thanked this post: ricko_uk
« Reply #4 on: February 27, 2020, 02:25:35 am »
Thank you Circlotron and Greybeard,
Circlotron, look forward to it. Thank you! :)
Greybeard,
- signal amplitues as mentioned from few tens of mV to 4.5V. It depends on the configuration for every specific application. Most cases are between 1.5 and 4.5V.
- the signal is as just a fixed sinewave
- detection of both positive and negative but no need to differentiate (i.e. a full wave rectifier would solve that)
- source and output impedances are buffered with op-amps so generally speaking at this stage no major issues there that I can think of
Thank you both :)
Offline Circlotron
« Reply #5 on: February 27, 2020, 10:06:11 am »
Here it is.
Hope it serves as a good starting point.
