Author Topic: 50ohm Oscilloscope Straight Through Termination BNC to BNC  (Read 2196 times)
Offline dazz1Topic starter
« on: August 06, 2020, 10:38:28 pm »
Hi
50ohm through terminations are most commonly used to terminate a 50ohm cable at the input of an oscilloscope.    They stop signals being reflected back down the cable.   They can be expensive.
I found a source on Aliexpress that is fine for general electronic workshop use.
https://www.aliexpress.com/item/33027400993.html?spm=a2g0s.9042311.0.0.27424c4ddHDFlc
If the link doesn't work in the future, search Aliexpress for "DANIU 1Pcs Y1078 50 BNC Male To Female Plug High Frequency Test Socket for CCTV System Connection High Quality"
You can see that the title doesn't really say what it is.  I was only certain when I dismantled it.
The termination consists of 2x 100ohm leaded resistors that are accessible by unscrewing the adapter.  I am considering replacing those with 4x  200ohm SMD resistors to raise the frequency response to a few GHz to plug into my 60MHz analog scope.  Why would I do that?? Because I can !!  8)
Dazz
« Last Edit: August 06, 2020, 10:44:12 pm by dazz1 »
Dazz
Over Engineering: Why make something simple when you can make it really complicated AND get it to work?
Offline thm_w
  • Non-expert
Offline ChristofferB
  • Chemistry phd student!
    • My channel:
Re: 50ohm Oscilloscope Straight Through Termination BNC to BNC
« Reply #2 on: August 06, 2020, 11:12:01 pm »
What is the advantage of this, at 60 MHz over a BNC Tee with one arm terminated into 50 ohm? Aside from the obvious style points
--Christoffer //IG:Chromatogiraffery
Check out my scientific instruments diy (GC, HPLC, NMR, etc) Channel: https://www.youtube.com/channel/UCZ8l6SdZuRuoSdze1dIpzAQ
Offline David Hess
  • DavidH
« Reply #3 on: August 07, 2020, 01:05:56 am »
The stub length of the high impedance input after the termination ultimately limits performance so even a 1 GHz termination is sufficient.  Better performance requires moving the switchable termination to a point inside of the oscilloscope or using a coaxial relay to switch between high and low impedance inputs.
Another option to reduce return loss is to insert an attenuating pad before the feed-through terminator.
Offline magic
« Reply #4 on: August 07, 2020, 06:45:17 am »
Another thread:
https://www.eevblog.com/forum/projects/home-made-feed-through-terminator-for-bnc/
I built this and couldn't or could barely tell any difference in rising edge on a 200MHz scope.
Both looked pretty much spot on, though the generator also was an uncalibrated DIY job, I just tried my best.
« Reply #5 on: August 08, 2020, 10:17:04 am »
It was cheaper to buy a pair of through-terminators than to buy Tees and 50ohm loads.
Dazz
Dazz
« Reply #6 on: August 08, 2020, 10:45:24 am »
The two 100ohm leaded resistors used in the Aliexpress through terminator are only 1/8W.
Using smd resistors to improve the frequency response wouldn't make the slightest difference on my 60Mhz scope, and my Spec-An already has a 50ohm input.  If done the right way, it would increase the power rating.  As the links above in other posts show, it would be cheap and easy to replace the leaded resistors with SMD resistors.  If care is taken with the physical layout, then the frequency response should be improved.
Dazz
Dazz
Online tggzzz
« Reply #7 on: August 08, 2020, 10:58:08 am »
Don't forget the effect of the scope's 20pF (or 15pF) input capacitance.
As you probably realise, in RF circuits a pad is often used to reduce such effects, on the grounds that gain is cheap, but reflection coefficients are a pain. A 20dB pad has the advantage of making the mental arithmetic simple.
