Hey guys, I'm having a bit of a dilemma here regarding conventional vs electron flow in my circuit design.
Basically, the OUT connector here is going to a motor controller. Said motor controller also supports regenerative braking, sending power back up the same lines.
What I'm trying to do, is to only allow the regen power to charge the batteries after passing through the CHARGE FET.
Conventional flow says this would work:
However, electron flow says it wouldn't? :
(Ignore the 2 useless misplaced arrows)
Is this what I actually need?
This has me totally stumped!
Dan
