Author Topic: Just an interesting paper from TI  (Read 758 times)
Offline Terry BitesTopic starter
« on: October 13, 2022, 04:49:46 pm »
https://www.ti.com/lit/SLYY200
Some noteworthy stuff for those of us that like a quite psu.
The following users thanked this post: Electroplated, mag_therm
Offline niconiconi
  • Country: cn
Re: Just an interesting paper from TI
« Reply #1 on: October 13, 2022, 06:34:24 pm »
One of the main approaches to reducing high-frequency emissions is to minimize the power-loop inductance.  Step-down converters from TI such as [...] move away from bond-wire packages to leadframe-based flip-chip (HotRod) packages that help lower the power-loop inductance and in turn reduce switch-node ringing
Analog Devices also has a product line called Silent Switcher 2, which also uses an improved packaging technique like TI's. In addition to low inductance footprint, ADI's packages also use embedded capacitors for low-ESL bypassing.
These certainly are great innovations, but on the flip side (no pun intended), the use of low-ESL, high density QFN and BGA packages makes an otherwise routine repair of a power supply rail become a tricky and challenging task.  :-// But I guess any technology comes at its own cost.
Offline ogden
  • Country: lv
« Reply #2 on: October 13, 2022, 07:03:39 pm »
Do not blame manufacturers but consumers who do not care how repairable devices are and how long they last - at the time of the purchase. Manufacturers just offer what is demanded by market.
