Author Topic: "555 Timer is soooo versatile", really?  (Read 12959 times)
Offline bsfeechannel
Re: "555 Timer is soooo versatile", really?
« Reply #50 on: October 13, 2022, 02:01:04 am »
I recently acquired a used GW Instek analog scope. The calibrator was a little off in frequency, so I resorted to its schematic and what, do you suppose, provides the 1KHz calibrated signal? You guessed it: a 555.
And here it is in all its glory!
Now the calibrator is calibrated to spec.
« Last Edit: October 13, 2022, 02:05:59 am by bsfeechannel »
Offline Electroplated
« Reply #51 on: October 13, 2022, 06:20:38 pm »
Ha, found another of my 555's in a led garden light, forgot about it, not surprising as it was over five years ago when I build the circuit, its just a crude and rude drop down switching reg that drops the 12v to 5v for the led. Dam LED gave up the ghost a few days ago, Once the led was swapped out, the light sprung back to life, not very exciting I know, but still very much 555 related !
I wonder if it's actually any more efficient than just using a resistor in that application. Or 2-3 LEDs in series with a resistor. Most garden lights have a switching converter because they're stepping the voltage UP to run a white LED from a single AA cell.
Its one of those colour changing led globes, the LEDS need 4.5v each to work correctly. There are many ways to derive 5v from 12v but I went with the 555 as it was on hand at the time. At the other end of the scale we have a lampost type light that I modded so the 12v supply was stepped up to power three flame effect neon candle type bulbs, it also used a 555 and a coil to boost the voltage.
Its works but not very efficient so I designed a similar lighting effect with orange Osram SMD leds and CC driver, far brighter and more efficient.
All this garden lighting was intended as a simple project but over time it got way out of hand and now I just have lights or ornaments chucked at me with the instructions  'to do something with it'.  ;D
50 years working with electronics and I still wonder how small parts can have all that smoke inside !
