For example:
LME49721: Single 5V RRIO audio, but weak output drive,
OPA342: Single 5V RRIO, worse distortion
etc.. Just google for RRIO audio opamps. There are a lot of them, but mostly they are sort of a compromise and must be well chosen for the application specifically. For example, probably can't use LME49721 as an output cable buffer, and so.
Also there are those that are not RRIO, so beware of the maximum signal levels with these:
LM4562: Single 5V capable, small THD, small noise and great GBW, 600ohm drive
Thing is with these, when price considered, if it wouldn't be better to get a cheaper opamp and give it more V supply. There are lot more choices I guess for +-5V supply. (TLE206x, even OPA1632 fully differential opamp, etc..)
