Hello all!
I would like to supply a circuit with voltage, however, I am still somewhat inexperienced and hope that someone here may share his knowledge with me.
Background: My circuit is powered by a 2S LiPo battery via a battery charge controller (Texas Instruments BQ25792). So the output voltage of the charge controller ("VSYS") is in the range of 6 to 9 volts, with a nominal voltage of 7.4 volts.
I now need two voltage rails: One rail with +3.3 volts and one rail with +5 volts. The 3.3V rail will need about 1 amp and for this I have provided a buck converter as effective as possible. The 5V rail will draw much less current with a maximum of 200mA (generously sized).
I am unsure of the best way to implement the +5V rail now. One option would certainly be to add another buck converter. Is this something that would normally be done? What alternatives do I have (especially in terms of space requirements and number of components)? A simple linear regulator would be nice, but would most likely run at the temperature limit quickly, right?
Thanks a lot,
Vulpecula
