Author Topic: 5V to 24V Step-up Advice  (Read 6117 times)
Offline migsantiagoTopic starter
    • MigSantiago's Web Site
« on: July 20, 2010, 09:58:59 pm »
Hello!
I want to convert a 5V USB supply to a 24V @ 30mA supply. I will use it for audio signals so I would like it to have a switching frequency of 100kHz or more.
Is there any simple IC that can step-up this voltage with low noise? The 24V load is just 15mA or so, but I am giving it a little extra window of 30mA just to be on the safe side.
Thanks for your tips!!
Offline tecman
Re: 5V to 24V Step-up Advice
« Reply #1 on: July 20, 2010, 10:53:18 pm »
There are quite a few chips that can do this.  Personally I like the 34063A for doing a variety of SMPS jobs.  It has an internal switch transistor, reference, and error amp.  As far as the noise issue, it will be more a function of the layout, grounding, proper caps and perhaps some additional L on the output as a filter.
Paul
Offline Zero999
  • 0999
« Reply #2 on: July 20, 2010, 10:59:11 pm »
Does it need to be regulated?
If not you could use a charge pump which needs no inductor, just capacitors and if you make the frequency high, the capacitors can be small ceramic disc.
« Reply #3 on: July 21, 2010, 01:49:12 am »
Hi guys!
Tecman, that's a great IC, I checked its formula and you just have to calculate R1 and R2 in order to obtain the Vout you want. I think I will use it just in case nobody else posts a better one.  ;D
http://focus.ti.com/general/docs/lit/getliterature.tsp?genericPartNumber=mc34063a&fileType=pdf
Hero999, it has to be regulated because it will feed a microphone and the bias voltage may oscillate if the 24V supply is not regulated.  :-[
Online NiHaoMike
    • Facebook Page
« Reply #4 on: July 21, 2010, 05:12:34 am »
There are plenty of boost converter chips out there. Look through the selection menus of Maxim, TI, or Linear, just to name a few.
« Reply #5 on: July 21, 2010, 01:00:45 pm »
Hi Nihaomike!
I was looking for them yesterday in TI.com but I could only find 2. I'd better use one that has been tested and approved by someone else.  ;D
