Welcome,
Guest
. Please
login
or
register
Did you miss your
activation email
1 Hour
1 Day
1 Week
1 Month
Forever
This topic
This board
Entire forum
Google
Bing
Home
Help
Search
About us
Links
Login
Register
Electronics
Projects, Designs, and Technical Stuff
TPS54232 buck regulator
« previous
next »
Print
Search
Pages: [
1
Go Down
Author
Topic: TPS54232 buck regulator (Read 1493 times)
LukeW
Frequent Contributor
on:
August 03, 2016, 12:53:07 pm »
Your basic, typical regulator stage with Vo=5V, Io=2A max, Vi=24V. Vo is actually set slightly high on purpose, at about 5.25V.
I was just looking for a quick bit of peer review on this, a sanity check to ensure that nothing silly is missing.
Logged
Kean
Supporter
Country:
Embedded systems & IT consultant
Re: TPS54232 buck regulator
Reply #1 on:
August 03, 2016, 02:15:47 pm »
Looks basically fine to me.
You might want to increase R22/R23 values and decrease the ratio though. Those values are lower than typically recommended (waste of 2mA?), and with that ratio you'll be enabling the regulator from something like 9V which seems low if you're expecting a stable 24V supply.
Logged
tszaboo
Super Contributor
Country:
Current job: ATEX product design
Reply #2 on:
August 03, 2016, 02:42:51 pm »
Fuse or two, ESD protection, reverse input protection (everyone loves the popcorn capacitors). Any of these might be unnecessary. I would put some extra lower value ceramics on the output (100n), just for good measure. You can never have enough capacitors.
Logged
Niklas
Country:
Reply #3 on:
August 03, 2016, 03:18:29 pm »
LC-filter between +24V and the two input capacitors to attenuate conducted emissions. Could be possible to reuse footprints for L2 and C19.
As NANDBlog mentioned, add some input protection. You don't need much wiring, just a couple of inches, to create turn on transients that will exceed 30 V as stated in absolute maximum ratings. We have a board that is supplied with 28V, with 2x100nF at the input, that peaks at about 50V with a linear PSU and 2x20cm 0.25mm^2 wires.
http://cds.linear.com/docs/en/application-note/an88f.pdf
Logged
Print
Search
Pages: [
1
Go Up
« previous
next »
Electronics
Thanking...
EEVblog Main Site
EEVblog on Youtube
EEVblog on Twitter
EEVblog on Facebook
EEVblog on Odysee
