This thing has 2 victims so far.
1)I'm powering a LCD volt/amp with 4.3V from a separate winding, and it shares gnd with the power rail gnd. I hooked up a nice little LCD temperature sensor to the 4.3Vdc winding for power, and touched its nice shiny metal probe to the 2n3055 42V collector, expecting to measure the temperate...NOT expecting that the probe tip was somehow a short or near short to gnd, so a little zap sound and thats it.
I never read anything on it or checked anything 1st, so assumptions fried it. It's 5V regulator is zapped, I hope nothing digital is damaged. I'd use the hotair station on that tiny Reg. but there's a plastic power snap/clip/cable connector 1mm away basically. I have the special kafton? tape, could that save the plastic 1-2mm away? Very tight for the iron too.
The 2nd victim was itself, I'm not quite sure what did it. I never had the protection diodes in, I had a short/wire for R12 S.O.T. meter circuit for some reason, which I'm not using, I never had the CV/CI part added to the bottom. Could have been solder debris, I just made it this week
Turns out I fried the lower 5.1V Zener and the coarse V adj. pot, I used 44k for the 25k (I know that it basically maps the kilo-ohm's set there, to the output voltage, I never went over 33V)
Just before I was running a LM317/LM337 circuit from this...I never added a load to it, so that unit used a few mA. Did that fry it, with no protection diodes on either the PSU or LM317/ unit?
IDK (I added them to the LM317 circuits I've made)
Then I had that unhooked, and all seemed find and I quickly turned voltage down to zero to check something, last I saw before smoking was -15V on the volt/amp meter (the ouput put LCD I added).
I had it down to zero several times before and it did go a bit negative according to DMMs and the LCD vol/amp meter , so I quickly went back positive.
So somehow that 44k coarse voltage pot. and the xener fried.
So I didn't really know what smoked , I found the zener, the rest checked out in circuit, but I missed the 44k pot. So I pulled it apart and checked the diff. amp and amplifier transistors, they were all fine.
So now I'm have it working again, but I added some higher wattage resistors and more stable resistors in a few places, a bunch of switches, protection diodes, the full constant current and V(-)output. I haven'y tied that function at all yet tho.
The 10.3VAC rail is not really enough, just idling, I get about 13.8Vdc w/30-40mV ripple w/ 4700uF across the rail. I haven't tried playing with the zener voltages, lots to try, later. Lots of fun, lots of fun, no sleep, crazy electronics party all week.
Right now, I'm getting a lot of noise or oscillation at the base of transistor Q4, for the current limit divider. The red overload LED I have used, is coming on and off, to varying amounts, when it should not be I don't think. I have a 10cm wire running from the 1k P3 to the power rail board. If I clamp my hand over that wire, I can sometimes short the AC and the LED turns of.
Cheers to anyone still reading,
So there's a few mV of 120Hz ripple at the base of Q4, but, there's also something much higher frequency, (my scope sees radio 99.1MHz a lot). When that picks up and the LED is conducting I'd start getting 10-20mV (I just shut off the scope). But I can see the signal grow and shrink and any freq/, its very real.
I know the basics and equations for high/low pass filters...but not their subtitles, .so far I only tried 2 caps from the -5.1V rail to the base, it's an improvement, but still not consistent.
thats enough rambling for now
