You mean, "Curse you, Apple, for not adhering to an industry standard that hadn't been invented yet!"?
Even after there was an industry standard, Apple adopted further custom standards. I do not really blame them though because when the USB-C standard for charging came out, the first advertisements I saw were for charge controllers that provide DRM protected chargers. The USB-C charging standard built incompatibility in.
What I do blame Apple for is atrocious quality of their own USB chargers and adapters. Go read the reviews on their web store from their own customers.
None of this makes sense... Apple hasn't pushed any 'custom standards' since USB-C. (In fact, Apple helped design and push USB-C; you're welcome!) Apple takes a lot of shit for being some tightly closed walled garden, but it just isn't true.
Look at all the Open Sores projects they've made major contributions to (or outright created)! Here's two huge ones: WebKit and Clang/LLVM.
Look at all the industry standards they've helped to either design, push or popularize: USB 1.1, 802.11b WiFi, FireWire, DisplayPort, Thunderbolt, USB-C. That's just off the top of my head, there are many more.
In each of those cases, Apple could have come up with their own protocol or proprietary software, but they didn't. Instead, they adopted a new, cutting edge standard or software project and designed it into their products, helping to popularize it. In a lot cases they even joined the design committee of the standard to help shape it!
As for the quality of their chargers, I'm not sure what you're talking about. They've always been very high quality. I've owned every iPhone from the original to the 5S and never had a single issue with any of the chargers. In fact, the only problem I can think of is when they first came out with the tiny 1"X1" cube chargers (with the iPhone 3G if I remember correctly). They ended up doing a preemptive recall on the US version, as there was a chance the prongs could break off in the wall if something fell on the charger while it was plugged in. They redesigned the charger so the prongs are firmly anchored to the case.
In 10 years of using iPhone chargers (and supporting an office of 50 iPhone users for 3 years, plus a dozen friends and family), I've never seen one go bad. USB cables, yes, but not USB chargers. The same applies for the MacBook power bricks; the cables tend to fray near the MagSafe connector after a few years of hard use, but luckily you can buy replacement cables.
