Author Topic: 74HCT74 NXP vs Texas  (Read 2657 times)
Offline Jan Audio
« on: December 26, 2018, 03:15:23 am »
Hi, merry cristmas.
I have another problem :
When i change my 74HCT74 from NXP to Texas instruments it dont works anymore.
I have a square wave to 8K2 resistor going into a 2n2 capacitor,
the capacitor out goes with a 10K and diode to ground and to the CLK input of the 74HCT74.
Why is it different ?
thanks
btw : it does work somehow only it toggles twice really fast so the output looks like always on state.
« Last Edit: December 26, 2018, 03:28:39 am by Jan Audio »
Online rhb
Re: 74HCT74 NXP vs Texas
« Reply #1 on: December 26, 2018, 03:47:39 am »
Perhaps you should post a schematic?  That way readers would know what you're trying to do.
Offline DaJMasta
    • medpants.com
« Reply #2 on: December 26, 2018, 03:53:20 am »
Is the TI part also an HCT series chip?  Some different families require different voltages or have different response characteristics (or are open collector outputs, like the F series).
Hard to tell exactly from your description, but is your clock input signal AC couple but not biased to stay above negative voltages (can cause erratic behavior)?  Also could be that the TI part is configured to use any old edge trigger whereas the NXP part is only rising or falling edge - giving you 2x the switching rate - the datasheet should be able to tell you if that's the case, though usually these are different part numbers on the package (the 74 model should be positive edge triggered only).
The following users thanked this post: engiadina
Offline Jan Audio
« Reply #3 on: December 26, 2018, 04:00:08 am »
Yes the Texas is the SN74HCT74N.
« Last Edit: December 26, 2018, 04:02:23 am by Jan Audio »
Offline podericof
« Reply #4 on: December 26, 2018, 04:01:16 am »
Hi there,
can you also tell us the complete PN for the 2 ICs?
Offline Jan Audio
« Reply #5 on: December 26, 2018, 04:02:40 am »
Hi, sorry what is a PN ?
Texas is : SN74HCT74N
NXP : 74HCT74, i have to look.
Offline blueskull
  • Country: cn
  • Power Electronics Guy
« Reply #6 on: December 26, 2018, 04:03:30 am »
Probe the input voltage to the logic chip. Different company chips have different design. They both conform to a single standard (VIL range, VIH range, etc.), but the exact value is not guaranteed.
Part number.
Offline Jan Audio
« Reply #7 on: December 26, 2018, 04:15:02 am »
The NXP is : 74HCT74N
Online wraper
  • Country: lv
« Reply #8 on: December 26, 2018, 04:34:54 am »
If it does not work and IC is not faulty, there is something wrong with your circuit. Just happens to be that one of them marginally operates.
Offline Jan Audio
« Reply #9 on: December 26, 2018, 04:38:47 am »
Thanks, i will re-check my circuit again, hope the Texas works since i have 100 piece.
Online wraper
  • Country: lv
« Reply #10 on: December 26, 2018, 04:39:42 am »
You shall not input signals with slow rise/fall time into CMOS ICs to begin with. The only exception are ICs with schmitt trigger inputs. You have not described diode orientation as well. As people already said, post the schematic.
Offline Zero999
  • Hero999
« Reply #11 on: December 26, 2018, 06:35:03 am »
What are you trying to achieve the the resistors and capacitor.
Offline Bassman59
  • Yes, I do this for a living
« Reply #12 on: December 26, 2018, 11:34:29 am »
Post a schematic.
Offline David Hess
  • DavidH
« Reply #13 on: December 26, 2018, 11:49:53 am »
For the same part from different manufacturers, some clock inputs are implemented as schmitt triggers and some are not but this is not always reflected accurately in the datasheets.  This may be one of the later cases and it is exactly what I would expect of the 74HCT74.
The only way to be sure is to either qualify the parts or include your own schmitt trigger before the clock input if you are going to use different manufacturers.
Offline Jan Audio
« Reply #14 on: December 27, 2018, 12:26:04 am »
Here was the NXP schematic :
                                              2N2
[ 12v waveform ]-----[8K2]-----||------+----[10K]---ground;
                                                          +----|<4148]---ground;
                                                          +----[CLK]
I fixed it with this for Texas :
                                              2N2
[ 12v waveform ]-----------------||------+----[1K]---ground;
                                                          +----[CLK]
Maybe it is a bit short circuit like this ?
Ok, thank you i did not know.
« Last Edit: December 27, 2018, 12:27:47 am by Jan Audio »
Online wraper
  • Country: lv
« Reply #15 on: December 27, 2018, 12:33:16 am »
                                                          +----[CLK]
                                              2N2
                                                          +----[CLK]
Some piece of nonsense you made there. If you need to reduce voltage from 12V, why not use resistive divider of resistor + zener diode? And why don't you draw normal circuit?
Offline Jan Audio
« Reply #16 on: December 27, 2018, 12:55:08 am »
I have no zeners in house, another parts series to buy ?, do i really need them...
If the NXP was still available i would buy them.
I dont have software to render schematics, got any free ones ?, they should build it in this website one that locally generates on simple info.
« Last Edit: December 27, 2018, 12:58:24 am by Jan Audio »
Offline NiHaoMike
    • Facebook Page
« Reply #17 on: December 27, 2018, 01:10:35 am »
DaveCAD might be really limited in features, but is definitely the easiest to use.
Fork: https://github.com/scanlime/davecad
Original: https://github.com/EEVblog/DaveCAD
The following users thanked this post: Ysjoelfir
Online wraper
  • Country: lv
« Reply #18 on: December 27, 2018, 03:42:39 am »
2 resistors for divider sounds too difficult? What's the point using capacitor to begin with?
Offline Jan Audio
« Reply #19 on: December 27, 2018, 03:43:47 am »
The saw wave i put in now is from 6,6v to 11,5v.
Offline SiliconWizard
« Reply #20 on: December 27, 2018, 03:56:36 am »
Just take a look at the datasheets. The NXP one has a schmitt trigger in the clock input (actually most NXP logic parts have schmitt trigger inputs AFAIK), wheras the TI most likely doesn't (the DS doesn't make any mention of it).
NXP: https://assets.nexperia.com/documents/data-sheet/74HC_HCT74.pdf
TI: http://www.ti.com/lit/ds/symlink/sn74hct74.pdf
The lack of a schmitt trigger in the TI part makes the internal clock signal bounce in your case (it's not a digital signal with "clean" edges but an high-pass filtered signal.)
Don't remove the series resistor. You're going to kill the 74HCT74 eventually. If you didn't kill it yet, it's thanks to the high-pass filter which limits the duration of the 12V pulse and the internal clamping diodes. You may end up frying one.
With this kind of circuit, your best bet is to use a 74HCT74 with a schmitt trigger clock input such as the NXP one (I'm sure there are other vendors with this).
You could also add a schmitt trigger buffer in front of it, such as the SN74LVC1G17 (it's a single schmitt trigger buffer, the LVC series should be ok for your requirements and it's easily available whereas the 74HCT1G17 is not.)
If this was meant to be in a product, the second option would probably be better, because using a "standard" part (a reference available from many vendors) and requiring specific features in it from a specific vendor is a recipe for potential supply disaster later on.
Offline Jan Audio
« Reply #21 on: December 27, 2018, 04:40:17 am »
Ok, many thanks.
Why did NXP quit ?, and why dont Texas has schmitt-trigger ?
I will take a look for other vendors, its for personal use only, thanks for the advice.
I also dont like to use more space on my circuit for a schmitt trigger.
Maybe Texas themself has also with schmitt trigger, i,m gonna find out.
Offline Zero999
  • Hero999
« Reply #22 on: December 27, 2018, 05:39:24 am »
Use a potential divider:
R1 = 4k7
R2 = 3k3
I used the site linked below to calculate the resistor values, which I divided by 10, to give more speed and noise immunity.
https://www.random-science-tools.com/electronics/divider.htm
Offline Jan Audio
« Reply #23 on: December 27, 2018, 05:41:08 am »
You cant divide 6,6volt off state and 11,5volt on state, the zener is needed also.
Offline Zero999
  • Hero999
« Reply #24 on: December 27, 2018, 06:10:47 am »
You're right, I missed the 6.6V and 11.5V part. The resistor values could be changed, but it would be marginal.
If you knew that, then why didn't you mention the zener diode before?
Change R2 for a 4.7V or 5.1V zener diode and keep R1 the same.
Zener diodes are not expensive.
« Last Edit: December 27, 2018, 06:40:44 am by Zero999 »
Offline Jan Audio
« Reply #25 on: December 28, 2018, 03:14:09 am »
The zeners might be usefull, i go look for those.
I think the chip wont break since the difference is about 5 volt.
+ the saw is also a slow ramp.
As long it works im happy for now, going to solder a new circuit.
Offline IDEngineer
« Reply #26 on: December 28, 2018, 05:30:11 am »
I have a remarkably similar situation in one of my existing designs, and I specified the 74AHC74 specifically because it has a Schmitt Trigger on its CLK input. There is also a 74AHCT74 version if you need the TTL compatible logic levels. A quick glance at DigiKey shows this part stocked in many thousands of pieces and available from at least two manufacturers. Cost starts under $0.25/100's.
My political litmus test: I will vote for any candidate, regardless of party affiliation or positions on other issues, who promises to abolish the TSA.
The following users thanked this post: Jan Audio
Offline Jan Audio
« Reply #27 on: December 29, 2018, 02:25:44 am »
Thank you Engineer, usefull information.
Offline jmelson
« Reply #28 on: December 29, 2018, 07:17:18 am »
If you really need to work with 12 V signals, maybe you should use a 4000 series part.  I think the equivalent is a 4013, but the pinout will not be identical to the 74xx74.
These are much slower parts, and might work without additional components.  But, if a slow transition on the clock is the problem, then a Schmitt trigger on the clock is the very best solution.
Jon
Offline David Hess
  • DavidH
« Reply #29 on: December 29, 2018, 07:36:49 am »
Or use 74Cxx which is high voltage CMOS like the 4000 series but with 74xx pinouts and functions.
Offline IDEngineer
« Reply #30 on: December 29, 2018, 08:09:14 am »
I had the exact same idea, but then I looked at specs and availability... the 74C74 is listed as "obsolete" from many manufacturers and the only one in stock (at DigiKey anyway) wants $7 each in low volumes. Also, the spec sheets I checked do not mention a Schmitt Trigger input on the clock, nor any other input.
There were other CMOS-based 74-series parts back in the day, so perhaps one of those is available and would work, but I'll leave such research as a worthwhile exercise for the OP. If he's got a $7 budget to solve this problem, my 25 cent recommendation and a couple of FET's would allow him to use 3.3 or 5V logic to control a 12V environment and still leave enough money for lunch.  :)
Offline David Hess
  • DavidH
« Reply #31 on: December 29, 2018, 10:01:38 am »
Clock inputs often use Schmitt trigger operation to avoid the exact problem you had but like I said, this is not always reflected accurately in the datasheet and it varies between manufacturers for the same part.
Yea, availability and pricing will be a problem for such an old part and technology.  I do not know offhand what is still considered current.
It is too bad because high voltage 4000 and 74C series CMOS are very useful in mixed-signal applications which now have to be redesigned to use a lower voltage logic family and level shifting.
Offline vk6zgo
« Reply #32 on: December 29, 2018, 02:02:48 pm »
IC manufacturers are not always innocent when it comes to strange things happening when using supposedly identical devices only separated by a fair few years between manufacture.
I had to work on a piece of equipment which used a mono stable IC in the 4000 series, where it was used to provide a quite long "on" time.
Unfortunately, one of these devices became lost.
"No worries, there are plenty in the Store!"
When I tried to use the new one, it kept timing out early, so the equipment didn't work.
The same result with all the new ones in the Store.
It turns out that the manufacturer originally specified the mono for a very large range of "on" times, but some users had problems with them with short
"on" times.
The answer was to change the design, so that the original part number was good for fairly short durations, & introduce a new part number for people who want long durations.
We had to specially order the "long duration" version, replace the originals with the new type in both the units using them, generate an internal Tech note, & change the original schematic.......Aaaarrrrgggghhhh!
Offline Jan Audio
« Reply #33 on: January 03, 2019, 01:48:04 am »
So i build the new circuit, now i have something weird that wont happen with the NXP :
If i touch with the scope or even a loose wire the output of the SN74HCT74N, all working good, soon as i release the wire, the thing stops working.
In my circuit i attatched the output signal to the base of a transistor with a 470K resistor.
I hope the SN74AHCT74N dont have that problem.
Can someone explain ?
thanks
Offline IDEngineer
« Reply #34 on: January 03, 2019, 04:07:52 am »
Classic behavior of a very high impedance node. Try lowering that 470K value, paying attention to the output current capacity of the '74.
Offline Jan Audio
« Reply #35 on: January 04, 2019, 03:15:32 am »
Thanks, i go read some datasheets.
With a 10K pulldown resistor also did not work.
Offline IDEngineer
« Reply #36 on: January 04, 2019, 12:17:00 pm »
Wow, do I wish we could see a non-ASCII schematic. Even pencil-on-napkin would be helpful.
Offline Jan Audio
« Reply #37 on: January 05, 2019, 02:20:45 am »
Ok, i will download DaveCAD somehow.
I cant find any software on this link :
Where do i download ?
« Reply #38 on: January 05, 2019, 03:00:35 am »
 ;D
Offline IDEngineer
« Reply #39 on: January 05, 2019, 03:44:02 am »
Suggestion: Just sketch out your schematic on a piece of paper, scan it, and post it here. Stay focused on your actual project for now. Learning any CAD-style application will take non-zero time that you could instead be using to answer your circuit questions.
Offline Jan Audio
« Reply #40 on: April 05, 2019, 12:38:29 am »
Thank you again IDEngineer, the AHCT works perfect.
Offline IDEngineer
« Reply #41 on: April 05, 2019, 04:03:46 am »
Glad to hear things are going better! Sometimes "older" parts are still good solutions for certain kinds of problems.
Offline Gyro
« Reply #42 on: April 05, 2019, 04:10:03 am »
...and sometimes, understanding exactly what is going on, and not relying on marginal factors, makes reliable products!
Chris
"Victor Meldrew, the Crimson Avenger!"
Offline Jan Audio
« Reply #43 on: April 10, 2019, 10:05:16 pm »
Oh wait, i had to change the 8K2 to 5K6, i take 4K7 to be sure.
So there still is a difference between Texas and NXP.
The driving of the 470K resistor was ok.
Just to make this story more complete.
