Poll
EMI filters on Mains ( do you use them on DIY projects )
Whats is a EMI filter ?
1 (4.8%)
Yes most of the times
7 (33.3%)
No I do not need them
8 (38.1%)
Always
3 (14.3%)
No they are costly
2 (9.5%)
Total Members Voted: 21
Voting closed: December 07, 2011, 03:45:36 am
Author Topic: EMI filters on Mains ( do you use them on DIY projects )  (Read 3935 times)
Offline Kiriakos-GRTopic starter
  • Country: gr
  • User is banned.
    • Honda AX-1 rebuild
« on: August 29, 2011, 03:45:36 am »
EMI filter on Mains,
metallic box mostly found in respectable devices, in the AC input of them.
By voting you are showing how much do you care about them.  :)
Personally, I remove them from dead devices so to add them on my own projects.
Offline PeterG
Re: EMI filters on Mains ( do you use them on DIY projects )
« Reply #1 on: August 29, 2011, 05:11:47 am »
My projects are mostly low voltage and don't run directly off mains power.
Regards
Testing one two three...
Offline JuKu
    • LitePlacer - The Low Cost DIY Pick and Place Machine
« Reply #2 on: August 29, 2011, 05:45:27 am »
A few years ago I got a few integrated AC inlet/switch/EMI filter components. Whenever my project has an AC input, I use those.
http://www.liteplacer.com - The Low Cost DIY Pick and Place Machine
Offline Conrad Hoffman
    • The Messy Basement
« Reply #3 on: August 29, 2011, 07:59:43 pm »
I try to power things with wall warts, but if building something line powered I almost always use a Corcom or similar filter. The side benefit is they usually accept standard line/mains cords.
Offline Gall
  • Country: ru
« Reply #4 on: August 29, 2011, 08:57:03 pm »
I use Meanwell power modules, they have built-in EMI filters and fuses.
The difficult we do today; the impossible takes a little longer.
Offline Psi
« Reply #5 on: August 29, 2011, 09:04:04 pm »
Totally depends what your project is doing.
No point putting an EMI filter on an electric blanket.
Offline corlickmark
« Reply #6 on: January 08, 2012, 09:32:34 am »
Well, EMI filter is just like any any other filter that try to reduce the frequency interference by filtering the frequency. I like to collect them and make a note about their rating so that i can use them in some of my own small projects like frequency jammer, FM transmitter etc.
