I'm repairing a Pioneer RT-707 tape recorder, and have tracked down a recording problem to a noisy 7V Zener (7.2V actually) in the REC/ERASE power supply. I considered buying a replacement, but because it would almost certainly have a different voltage, I would have to futz around to get the same Vout (30.94V)
or adjust everything downstream (i.e., a factory recalibration on that section). So...
I was thinking about using a TL431 "adjustable zener" as a drop-in replacement. I don't see many projects in the audio forums about this, so I thought I'd get some EEVBlog opinions. Here's the existing circuit:
(subsection of
At first, I was focused on just replacing the Zener. Then somebody happened to post a thermal image of this circuit
here, and both R332 and R334 are running at about 50C. I wondered if the TL431 should replace the Q308 transistor and the toasty resistors? After some simulations, I have this as a possible replacement:
- TL431 provides a ~31.6V reference for Q307, instead of a 7.2V reference to Q308
- R2 is a pot for dialing in the desired 30.94V output.
- R334 deleted
- R336 increased by 50% (cooler!)
- C323 and C324 deleted because the TL431 doesn't like (or doesn't need) a capacitive load. R335 keeps TL431 stable WRT C325
- C325 reduced by 70%. This decreases startup time from 3s to <1s, and gives me a little more room. Things are a little cramped between the big caps and the heat sink for the transistors.
The ripple is reduced quite a bit, and I think the noise is 4x lower. This seems close to the "Figure 34. Efficient 5-V Precision Regulator" in the TL431 applications section, but what do I know? Umm... enough to find the problem, but not enough to solve it?
Any suggestions or comments?
Thanks
/dev
[Edit - removed R1]
