Hi, I have just began to design of my first function generator, which I'm going to build around an ILC8038. I would really appreciate your help on this project, and I hope others can also use this thread as a guide to make their own function generators.
I've been looking for a design on the internet for a few weeks, but so far I can't find any that I like; none of the designs have all the features I'd like, and I could only find one design with a display for the frequency. So, as I can't design my own circuits -since I'm just a beginner- I decided to put together various parts from a few designs with the features I like... and, this is where the problems began.
So far I made a simple prototype in a breadboard with just the core of the function generator -which seems to works pretty well-, and now I'm trying to attach another circuit that will display the frequency. This last circuit is based on a CD4047 multivibrator and a series of 7-segments displays through their respective CD4026 decade counters... well, this circuit:
But the problem is that when I connect the circuit for the display to the function generator, the nice and clean signal that I got before, and which now goes to pin 1 of the first decade counter, gets interferences from the pulse that the CD4047 multivibrator generates to measure the frequency. Even if I follow that diagram exactly -including the function generator on the top-right corner- I will continue to get interferences on the output from the display circuit.
I would really appreciate if anyone could help me solve this problem. How can I avoid getting interferences between both circuits? I was thinking of using something like an optocoupler, but I'm not sure it's the best way of doing it or even if it will work at high frequencies. Which would be the proper way of doing it?
By the way, can anyone explain me the function of D1 in parallel with R7? I think I understand what C11 does -limit the reset pulse sent through Q not-. But why does it also have a diode and a resistor in parallel with ground?
Thanks,
I will post the other parts selected for the final design later on in this thread; in case anyone is interested.
