I'm trying to design an audio circuit, where a 2V peak to peak sine wave (no dc offset) needs to be split into the separate top and bottom halfs of the wave, negative and positive, for further processing.
How would this be possible? I've tried diodes (as the voltage drop would be acceptable), but the common ground on the separate outputs, has the signals coming back together, and the sine wave is a little distorted at 0V. Is it possible, to separate the negative and positive halves of the waves, and then put them back together?
My other idea is possibly using a tiny center tapped 1:1 transformer?
I'm fairly new to electronics, so I apologize if this is an elementary issue I'm asking about. Pointing me in the right direction would be all I need, so then I can do the technical research myself.
Thanks!
