Hi all!
PREQUEL: I run a side business as an audio engineer and I the job I most often do is to mix a choir with around 30 hand held mics on stage. Dragging along a huge multi and a complete mixing console only for summing those mics into four vocal groups (bass, tenor, alto and soprano). I want a simple box with 8 XLR in and 2 XLR out. No phantom needed as I'll only use dynamic mics for this.
WHAT I WANT TO DO:
9 XLR inputs, each has a switch for which out it will sum to (except the one witch will be for simply adding a previous box to the sum)
8 digitally controlled preamps/attenuators
2 XLR audio out
2 XLR for RS-485 with max485 (IN/OUT for linking) with switch for inserting termination for last node
I want to use the preamps on my mixing console for the acutal preamping.
The plan is then, that I can have say 5 of these boxes on stage and use a 5 XLR multicable to the stage.
1 for bass, 1 for tenor, 2 for alto (this is where one box will feed into to 'link' input and just add itself to the sum) and 1 for soprano. And lastly, one for RS-485 into a control device I will make.
QUESTIONS:
Should I buffer the signal or simply just use a digital pot to create a remotely controlled LOG attenuation?IF BUFFER; How does one buffer a balanced signal?I'm scared if I just use a follower on each line that some distortion artificats (due to mismatches?) will make problems...? Is this a valid concern?
Thanks for your time!
EDIT: found a schematic I did a while back trying to get some of my thoughts down
. Since then I've decided to drop phantom power and use XLR for serial comms (always plenty XLRs during gigs). Probably the only thing that would be the same if I did it again is the digital pot. Terrible layout too, don't give it any attention. Thanks again.
