Welcome,
Guest
. Please
login
or
register
Did you miss your
activation email
1 Hour
1 Day
1 Week
1 Month
Forever
This topic
This board
Entire forum
Google
Bing
Home
Help
Search
About us
Links
Login
Register
Electronics
Projects, Designs, and Technical Stuff
"rail to rail" opamps
« previous
next »
Print
Search
Pages: [
1
Go Down
Author
Topic: "rail to rail" opamps (Read 3208 times)
blackjames
Regular Contributor
on:
August 26, 2012, 08:14:07 am »
hey guys and girls. does anyone happen to know if a lm358 dual opamp is a "rail to rail". if not, is there a rail to rail opamp with the same pinout in a dip-8 package. oh, and it must be able to run from 12V
Logged
T4P
Super Contributor
Country:
Re: "rail to rail" opamps
Reply #1 on:
August 26, 2012, 08:27:08 am »
no read the datasheets.
RR I or O? Which one do you need or do you need both?
http://sg.element14.com/jsp/search/browse.jsp?N=203333+110106794+110194056+110201817+110203418+110143499+110203475+110153802+110164512+110193321+110154163+110438682+110192203+110122037+110182464+110122189+110164563+110132412+110175723+110190058+110132415+110121815+110143097+110132747+110153833+110172659+110179247+110121757&Ns=P_PRICE_FARNELL_SG%7C0&locale=en_SG&appliedparametrics=true&getResults=true&suppressRedirect=true&isRedirect=&originalQueryURL=/jsp/search/browse.jsp%3FN%3D203333%26No%3D0%26getResults%3Dtrue%26appliedparametrics%3Dtrue%26locale%3Den_SG%26divisionLocale%3Den_SG%26catalogId%3D%26skipManufacturer%3Dfalse%26skipParametricAttributeId%3D%26prevNValues%3D203333
Logged
PSR B1257
Frequent Contributor
Country:
Reply #2 on:
August 26, 2012, 08:48:01 am »
Almost every (not 100% sure, maybe even any) dual op amp in a dip-8 package, has the same pinout.
You can also check out the parametric search of the manufacturer website e.g. LT:
http://parametric.linear.com/operational_amplifiers_%28op_amps%29#!cols_1030,1006,1021,1023,1012,1047,1866,1367,1004,1075!s_1004,1!gtd_!1030_2!1047_yes!1075_yes
Last Edit: August 26, 2012, 09:19:22 am by PSR B1257
Logged
In theory, there is no difference between theory and practice. But, in practice, there is.
Rerouter
Super Contributor
Country:
Question Everything... Except This Statement
Reply #3 on:
August 26, 2012, 09:20:28 am »
or a TS912IN
used them in a number of designs so far and havent had any issue with them
Logged
blackjames
Regular Contributor
Reply #4 on:
August 26, 2012, 09:52:30 am »
I think i will use the TS912 opamps because price dosentmatter that much. All specs are better anyway.
Logged
nctnico
Super Contributor
Country:
Reply #5 on:
August 26, 2012, 07:59:23 pm »
I recall some of the TS9xx opamps having a very large input current. So beware if the amplification is wrong.
Logged
blackjames
Regular Contributor
Reply #6 on:
August 27, 2012, 05:32:35 am »
ill do some tests once i order them
Logged
Print
Search
Pages: [
1
Go Up
« previous
next »
Electronics
Thanking...
EEVblog Main Site
EEVblog on Youtube
EEVblog on Twitter
EEVblog on Facebook
EEVblog on Odysee
