Author Topic: Simple AM/FM antenna design for RF signal generator  (Read 6087 times)
Offline davorinTopic starter
« on: July 02, 2014, 05:34:44 pm »
Good evenin' (o;
As now my Fluke 6060a/AN seems to have repaired himself I would like to use it also for testing older AM/FM radios as my lab is in the basement and no AM/FM reception is possible at all...
What would be the simplest design for an AM and FM antenna which can be directly plugged into the 6060a/AN signal generator?
Re: Simple AM/FM antenna design for RF signal generator
« Reply #1 on: July 02, 2014, 06:00:30 pm »
Simplest is a random wire antenna, preferably something about a quarter wave long at the frequencies of interest, but with low power and short range not necessarily so. If you are worried about SWR use a series 47R resistor to reduce reflections, and simply place one end in the BNC output connector.
If you want to get fancier use a quarter wave vertical dipole and a ground plane. Simplest for FM use is to go and buy a car antenna and simply plug it into the signal generator after replacing the antenna plug with a BNC connector. for better results use an external FM antenna without the reflector and director. I cut one down for use on 2m and it works well even with a 0.5W transmit power.
« Reply #2 on: July 02, 2014, 06:05:18 pm »
Can you recommend a good book/ebook for absolute beginners wanting to do antenna designs and RF transmitters? (o;
Offline poorchava
  • Troll Cave Electronics!
« Reply #3 on: July 02, 2014, 07:03:24 pm »
Ditto that, I became interested in RF lately and it's surprisingly hard to find any sources for total beginners.
Offline Fank1
« Reply #4 on: July 02, 2014, 11:20:46 pm »
Experimental Methods in RF Design
By:
     Les Hayward W7ZOI
     Rick Campbell KK7B
     Bob Larkin W7PUA
Available from ARRL
Best book I've seen in years.
Offline calexanian
    • Alex-Tronix
« Reply #5 on: July 03, 2014, 01:27:55 am »
Grab an ARRL antenna book/handbook and grab a ARRL general handbook while you are at it. All of the basics presented in a manner where anybody with basic electronics knowledge (that's in there too) can conceptualize how antennas work. A must have for RF basics.
Charles Alexanian
Alex-Tronix Control Systems
« Reply #6 on: July 08, 2014, 12:08:08 pm »
Found a program to calculate, which gives me around a 8cm sized antenna for 93.8MHz:
http://www.hamuniverse.com/dipivcal.html
Now for AM bands...this gets quite big....is there a calculator to make a transformer with 50Ohm input for the Fluke 6060a/AN and outputs directly to my AM band radios for testing?
Offline JOERGG
« Reply #7 on: July 09, 2014, 01:36:17 am »
Living in Switzerland you probably can read german. Then i would recommend this book about antennas:
http://darcverlag.de/Rothammels-Antennenbuch
If i write funny things, because english is not my native language, feel free to laugh. It is not always easy to find the right expression.
« Reply #8 on: July 09, 2014, 08:43:14 am »
Thanks..looks more like a bible than a book (o;
An Australian tour guide and book writer described our language like:
"We write a language we don't speak, and we speak a language we don't write" (o;
Online PA0PBZ
« Reply #9 on: July 09, 2014, 09:06:05 am »
That can't be correct. Since the wavelength is about 3 meters in the FM band a quarter wave dipole or groundplane should have elements with a length of about 75 cm.
So for a dipole:
 <-75->   <-75->
_______  _______
 That's probably the easiest to do, just hang it vertical and you will not have a directional effect and you will not need a ground plane.
Offline miguelvp
« Reply #10 on: July 10, 2014, 03:08:17 am »
So for a dipole:
 <-75->   <-75->
_______  _______
Math is simple.
Speed of light: 299,792,458 meters per second
Frequency: 93,800,000 cycles per second.
so 299,792,458  m/s divided by 93,800,000 cycles/s = X meters per cycle (seconds cancel each other), so 3.1960816417910447761194029850746 m per wavelengh cycle.
quarterwave 0.79902041044776119402985074626866 m or 80 cm (not 8cm)
Edit: 8cm would be for 10 times the frequency so 938MHz, maybe you put one 0 too many
« Last Edit: July 10, 2014, 03:54:47 am by miguelvp »
Offline Zad
    • Digital Wizardry, Analogue Alchemy, Software Sorcery
« Reply #11 on: July 10, 2014, 03:49:48 am »
For FM, use a telescopic antenna from an FM broadcast receiver. For AM, salvage a ferrite antenna out of the same broadcast receiver!
« Reply #12 on: July 10, 2014, 04:34:11 pm »
Ah...know now what confused the software....it ignored the decimal point...so 93.8MHz was for it 938MHz (o;
Offline eneuro
« Reply #13 on: July 11, 2014, 08:34:26 am »
What do you think about this amazon: Practical antenna handbook by Joseph Carr book?
Looks not so bad.
I need to send encrypted Morse coded bits from meteo station and receive hundreds of meters or a few kilometers/miles away using radio.
12oV4dWZCAia7vXBzQzBF9wAt1U3JWZkpk
“Let the future tell the truth, and evaluate each one according to his work and accomplishments. The present is theirs; the future, for which I have really worked, is mine”  - Nikola Tesla
