Bear with me here.
I am an armorer of the sport of fencing. One of our tasks at regional and national events is checking the gear for safety and functionality. One of those tests is on the lames (scoring jackets) for foil and sabre, which have a resistance limit of 5 ohms.
I recently upgraded a Kolbalt mini multi meter from a disposable battery to a rechargeable one (vid at
The issue I may run into is the sampling rate, which may be too slow on this unit for the test it's intended for.
As said in the vid, the storage bay for the meter I had intended to be used size limits the meter I now have to find (since he original meter is not available). The Kobalt measures roughly 4.25" tall, 2" wide, and 1.75" deep (including the battery, which is mounted on the back, outside the casing.
Finding a multi meter of the correct dimensions is not the issue...it's that I can't find the sample rates. I think the Kobalt is 2 times/second, which IS slow. Other armorers would prefer 7-8/second, if not higher which makes it easier to ID dead or high-resistance spots as the probe drags across the material.
To see the test I'm referring to, go to 18:35 at
https://www.youtube.com/watch?v=Je2iRZS-EE4&t=1120s...after a bit you'll see the armorer doing the work put a probe on the lame and you'll see the response on his meter. (personal notes...1 -- the guy who owns the lame is now a three-peat veteran's world champ in men's sabre in his division -- veteran 60. I fenced him at Nationals last year. 2 -- I was part of the armor staff for this event)
Any help in finding a meter close to the Kobalt's size (I DO have a little room on width and depth....not so much in height) with a higher sample rate wold be appreciated...I'm just not finding them with my weak search-fu.
Thanks in advance...I hope!
