Author Topic: A bit uncommon solid stage push pull output stage!  (Read 767 times)
Offline ELS122Topic starter
« on: August 18, 2023, 05:58:35 pm »
The output amplifier in a Realistic 8791 car EQ/Amp. Perhaps it's actually made by Alpine... it smells japanese and the switches in front are branded ALPS Japan.
Common emitter to get more voltage swing since they don't have a switch mode booster circuit, probably wasnt even common back in like 1988
The AC coupling from the pull to the push side is a bit odd.
The OPT looks like it's sized for around 10-15watts probably.
It's labeled 400W  :-DD Probably more like 100W combined. the front channels use a TA7250BP which lists 23 watts 4 ohms.
« Last Edit: August 18, 2023, 06:05:51 pm by ELS122 »
Online David Hess
  • DavidH
Re: A bit uncommon solid stage push pull output stage!
« Reply #1 on: August 18, 2023, 10:40:41 pm »
They already had the center tapped transformer, so why not an all silicon NPN or germanium PNP push-pull?
Offline Kim Christensen
« Reply #2 on: August 19, 2023, 04:58:29 am »
It's almost like they are using a stock output transformer in "reverse" so they can get more power out of a limited voltage swing. (12V supply rail)
ie: The transistor output stage drives a 1-2 \$\Omega\$ impedance and the 4 \$\Omega\$ side connects to the speaker.
