long reply, thanks a lot everybody for helping ! I learned quite some stuff today
Why not try an LM723 with pass transistor ?
Thanks! That looks quite interesting , i will most likely get one and play around with it .
I also like that it comes in a to-100 package
maybe you were thinking I was suggesting to use a ready-made one
that's exactly what i was thinking. I am now considering a switching supply too but i have a sound chip, video and composite encoder on 5V. Could that introduce too much noise? i guess not if i implement it correctly. idk
to prevent blowing all the chips on it if your 5V rail looses regulation and goes high, add a crowbar circuit across the output of your 5V regulator.
Thanks a lot! That's exactly what i was looking for about overvoltage
i have some stuff that i really don't want to damage
i used the pass transistor to spread the heat and make it cool easier
But now it has no over-current protection.
i hadn't though of that, the lm723 seems to sense current after the pass transistor which makes it a bit more appealing
Since you already have the LT1085, just use it as it is, without the additional pass transistor. The 2R series resistor will reduce the power dissipation. It just needs to be rated to 4W, but I wouldn't recommend going below 5W.
that sounds like the best option for now. I'll use that and then maybe check out the lm723 or the LM2576 mentioned by HB9EVI
Use a couple of LM317s in parallel with operational amplifiers to enforce current sharing.
that sounds quite interesting but it sounds complicated and i have no idea how i would go about implementing it
The transistor could also be placed in series to absorb some of the voltage drop instead of amplifying the current
so using a constant current on base-emitter and then the collector would go to the input of the regulators ?
wouldn't a resistor do a better job?
My advice would be to simply chain two linear regulators, so that each one will dissipate a part of the voltage drop.
That sounds great, maybe i can use my lt1085 to drop to something like 7 volts and then feed that to a 78S05 or whatever else.
wouldn't a dropper resistor be as good though?
is it to ensure that the voltage doesn't drop too much?
With LM1085 you'd have to be careful because the tab is connected to Vout
I use separate heatsinks for the regulators and transistors and they are also coated with something black that makes them non conductive but thanks, that could have ruined my day
Just get a car charger for a smartphone.
that aint no fun
I want to build the supply myself
I used for my Z80 devboard a LM2576: it's readily available, not too noisy and doesn't require who knows what heatsink for 12V -> 5V
but it doesn't look nearly as cool as the to-100 package of the lm723
seriously though, that seems like a good option but it supports up to 1.5 amps. Maybe i could cut down some stuff and use that
lots of good options to choose from
