I know there are plenty of fellow home builders
here. I have built a few projects Manhattan style on single or double
sided PCB. When using IC's I have mounted them upside down, their
grounded legs helping support them. This works fine, but changing a
failed one is a PITA. Has anyone devised a neat way of using them on
ground plane PCB, but in sockets, the correct way up? Flat or turned
pin sockets have short legs, I am musing on how to extend the grounded
pins neatly. A commercially made male / female turned pin "extender"
would be ideal. Making something like that in quantity is more
watchmaker or jeweler than automotive engineer
In a similar vein, what means has anyone used to mount terminal
sockets on ground plane? I have lots of the tow and three pin PCB
mount screw sockets for conventional through hoe PCB's, but a means of
using them neatly on ground plane board is welcome! Or an alternative.
I am inspired by the clinically clean W1VD work, but am some way away
from achieving anything remotely as elegant!
http://www.w1vd.com/137-500Phasingexciter.html
