Author Topic: A "high-end" 858D desoldering station  (Read 2244 times)
Offline mosafetTopic starter
« on: January 30, 2019, 01:49:29 pm »
The "cheap crap" 858D+ design seems really good to me. Yes, they're almost all (all?) made of Chinesium and a fire hazard. HOWEVER... What would happen if someone built an 858D clone with real, brand-name, parts? With real firmware, all the safety sensing and such. I think it's a really good clever design that only lacks some polish. Something in the $100US range.
I own the Weller. I own the Quick. I own several  858 clones. I compare them all. The 858 in terms of price versus performance is king! This design is elegant and price effective. They just need to use better quality parts and firmware. Then it would beat the best.
Yes, the Weller and Quick are faster in absolute terms but they're using actual 700+W/1000W elements whereas the Chinese parts are using 500W/600W parts probably due to safety design concerns. All things being equal I think the 858 design would destroy everything else.
Am I missing something?
Offline 001
  • Country: aq
Re: A "high-end" 858D desoldering station
« Reply #1 on: January 30, 2019, 03:32:25 pm »
What is for "with real, brand-name, parts? With real firmware"? Try some russian via google translate feature
https://radiokot.ru/lab/controller/10/
https://radiokot.ru/lab/controller/69/
Russians like 1602 displays at irons https://www.radiokot.ru/forum/viewtopic.php?t=2016  :-DD
« Last Edit: January 30, 2019, 03:35:20 pm by 001 »
Offline KL27x
« Reply #2 on: January 30, 2019, 06:49:32 pm »
Yes, indeed, you are. You seem to be missing brand loyalty, susceptibility to peer pressure, confirmation bias, and innate disdain for chinese imports. I bet you don't even use terms like "one hung lo."
The following users thanked this post: amyk, biot, cdev, jaromir
Offline GreyWoolfe
  • NW0LF
« Reply #3 on: January 31, 2019, 01:23:18 am »
You already have an 858D with quality parts, the Quick, I assume the 957DW?  I have the Quick 957DW and a Yihua 858D.  I am going to find someone local to give the Yihua to as it is just sitting on the shelf gathering dust.  The Quick is so much nicer, even with the somewhat stiff hose.
I doubt the Chinese units are using 500W/600W instead of larger elements for safety concerns.  I have seen the inside of both my units.  No comparison.  An 858D with a 700+W heater would probably be a real fire starter.  At lease, my Yihua was wired correctly and didn't need fixed.
Offline Shock
« Reply #4 on: January 31, 2019, 08:04:58 am »
There is already custom firmware and a replacement board someone posted. Rolling your own PCB using the open firmware is just a matter of putting in the time and effort. The problem with replacing the handle is it will drive up the cost to several hundred dollars. Should be able to keep it around $30 with a repurposed transformer, PCB, microcontroller, misc components etc.
https://www.eevblog.com/forum/reviews/youyue-858d-some-reverse-engineering-custom-firmware/
