Yes that is a possibility, myne had to work from 12V to 50V, so that made it a little more complex.
Benno
Meh, replace R2a in the previous schematic with a TVS diode, or better, add a TVS diode to limit the maximum gate voltage, but leave the resistor so it will firmly turn the FET off when it should be off.
Circuits like this switch quite slowly, because of the combination of resistors with the gate capacitance. This is OK for switching loads occasionally (such as also done with Relays), but if you want to switch loads fast (such as with PWM) then this slow switching may cause a lot of trouble and the FET is likely to let out it's magic smoke and die in a puff or a loud bang.
