Author Topic: A look at my Symmetricom GPSDO / 10MHz reference (OCXO + Furuno receiver)  (Read 550983 times)
0 Members and 15 Guests are viewing this topic.
Online Vgkid
Re: A look at my Symmetricom GPSDO / 10MHz reference (OCXO + Furuno receiver)
« Reply #100 on: January 23, 2016, 07:55:27 pm »
Thanks, I lost afew caps/ resistors when cleaning off the board. Ill let you know what else is missing.
im amazed how tiny the overall board is.
Offline davebb
« Reply #101 on: January 23, 2016, 11:01:08 pm »
Hi are you shore it was your cleaning that did it, as I had some caps missing/broken and U25 5 pin inverter was ripped of the board with the tracks,
good luck we are all here to help,spend a lot of time looking at the board and the photos on here to see if you have missed anything,
I have just made a display board to show the gps data, http://www.f4ctz.fr/?page_id=692
and the moded HEX file from Daniel F1RMB
I made mine on some vero board,i have just powerd it up and so far it is all working I just need to wire up the NMEA data to it from the Symmetricom gps
Let us all know haw you are getting on with your board
Dave 2E0DMB
Online Vgkid
« Reply #102 on: January 24, 2016, 04:49:47 am »
On unit 1; replaced the cap. Powered it up, draws 2.2A @5.4v.the dc/dc converter is whining, 5v is present at the 5v test point, the ocxo is only getting 9.6v.
unit 2: there is 1 missing cap, c30, but there are 2 loose caps floating on the board. Hmm, better start looking for others.
Offline TheSteve
  • Living the Dream
« Reply #103 on: January 24, 2016, 05:50:22 am »
Sheesh, they really were just tossed on the scrape pile when salvaged weren't they. Should be 10 bucks each in the condition they're in.
VE7FM
Offline davebb
« Reply #104 on: January 24, 2016, 10:13:38 am »
Hi you say that your input voltage is 5.4v,is that under load? as I found that the dc-dc do scream when just under volts,i am using a cheap adjustable dcdc powering mine so I can use a 12v supply,so I set it up with out load and when I  connected my Symmetricom  the dcdc on the  Symmetricom screamed and the output voltage wwas low like yours,so I then set it up under load and all was fine
Dave
Offline hs3
« Reply #105 on: January 24, 2016, 02:01:17 pm »
To satisfy my curiosity I also got one of these Symmetricom modules a while ago.
While testing I noticed that it seems to take a bit of a current spike when powering up.
Here are some examples at couple different input voltages. Power supply here was Rigol DP832 set to 3A current limit.
First 6V supply voltage:
5.5V supply voltage. Here the module was already warm. I think I had trouble powering it up also with 5.5V voltage in the past when it was cold. Same whining sound as with 5V when that happened.
5V supply voltage. Not starting, there is that whining sound from the board.
I have not tested how much larger the current spikes might be with a power supply without current limiting.
« Last Edit: January 24, 2016, 02:04:25 pm by hs3 »
Online Vgkid
« Reply #106 on: January 24, 2016, 03:57:53 pm »
The 5.4v is under load, i will turn it up a few hundred mV.
Offline davebb
« Reply #107 on: January 24, 2016, 04:13:52 pm »
Hi it should be up to voltage at that try another 100 or 200mv,reflow the solder joints on the dcdc,you will probably fine another 100mv will do it,you could allways get a cheap new dcdc adjustable buck boost new from china £1-2,
anyway I got my display working, the only thing it does not show all of my ,LON  W   0:56:00.451
what is good for us hams is it shows the locator
Dave 2E0DMB
Offline f1rmb
« Reply #108 on: January 24, 2016, 04:57:00 pm »
Dave 2E0DMB
Yeah, I guess there's a bug in the original code: badly handling negative (W & S). If you want, I can build you another HEX file for testing purpose.
Cheers.
Daniel
Offline davebb
« Reply #109 on: January 24, 2016, 05:11:18 pm »
Hi Daniel
Yes please that would be brill,i wish I could do that,
Thanks Dave 2E0DMB
Offline f1rmb
« Reply #110 on: January 24, 2016, 05:42:25 pm »
Hi Daniel
Thanks Dave 2E0DMB
Here it is. Please tell me if it works, this way I can send the fix to the original author.
Cheers.
Daniel
Offline davebb
« Reply #111 on: January 24, 2016, 05:52:08 pm »
That was fast,just going to try it thanks
,Dave
Offline davebb
« Reply #112 on: January 24, 2016, 06:14:45 pm »
Hi Daniel
All tested and working well  :-+
I just need a case now to put it all in, were did you find yours,
Thanks For your Help.
Dave 2E0DMB
Offline f1rmb
« Reply #113 on: January 24, 2016, 06:19:51 pm »
Hi Daniel
Dave 2E0DMB
Great, this is a great news.
Well, I bought my case from an old stock in an old (closing) shop, locally (the packaging was looking from the 70's ;-) ).
BTW, where did you find your LCD display, do you have any URL ?
Cheers.
Daniel
Offline davebb
« Reply #116 on: January 24, 2016, 08:00:03 pm »
No thank You,for all of your help,Daniel
can you please re write the original HEX file for the STD NMEA  SO I CAN USE IT WITH THE U-BLOX gps in the BG7TBL gpsdo so it displays all the LON in my loc,as I have another pic so I can make another one
Thanks Dave 2E0DMB
Have you stll got your ft817, I must get out with my one,
Thanks Dave
Offline f1rmb
« Reply #117 on: January 24, 2016, 08:04:37 pm »
Thanks Dave 2E0DMB
Thanks Dave
Okay, but I'll do that tomorrow (I think F4CTZ will made a similar update on his website).
Yeah, I still have my 817, it's really a nice piece of equipment :-) (and even much more with the BHI audio DSP module).
Cheers.
Daniel
Offline davebb
« Reply #118 on: January 24, 2016, 08:14:59 pm »
Thanks No rush,
Yes the BHI dsp works very well I fitted one in my old 817 that I sold,
But then I got another 817 and I do miss the dsp, but I do have the 10w dsp speaker from them,
Are you going to gpsdo lock your 817 :-+
Thanks Dave
Offline f1rmb
« Reply #119 on: January 24, 2016, 08:19:33 pm »
Thanks No rush,
Thanks Dave
I don't think so ;-) I fitted a TCXO-9 already, enough for HF bands ;-)
Cheers.
Daniel
Offline davebb
« Reply #120 on: January 24, 2016, 08:45:04 pm »
Yes I know but,
Same here for the 817,
like I posted I am going to fit it to my TS-2000 and I have locked my 4m transverter, very overkill,
Dave
Offline f1rmb
« Reply #121 on: January 24, 2016, 08:51:10 pm »
Here is the "original" version, decoding real NMEA sentences.
Cheers.
Daniel
Offline davebb
« Reply #122 on: January 24, 2016, 09:08:54 pm »
Thanks ,You know your Stuff,
I am only a prototype Wireman
We will Have to Talk on 20 OR 40meters
Thanks Dave
Offline f1rmb
« Reply #123 on: January 24, 2016, 09:17:49 pm »
Thanks Dave
Why not ;-)
Offline TheSteve
  • Living the Dream
« Reply #124 on: January 24, 2016, 09:54:57 pm »
Has anyone considered using TOD serial data the Symmetricom/Trimble GPSDO's can output every 2 seconds instead of the raw data?
btw, I have an FT817ND too, great rig.
VE7FM
