All:
Would appreciate some help. Needed to resolder some new connections to the RS232 header pins and something must have messed up the unit. It keeps reporting a GPS engine failure. Not sure if it was stray electricity, static, but at a loss where to go from here. Have tried to enter a location manually, no luck. I am certain the antenna is ok. Looked over the board with a loupe in the event I broke a component off, but can not find anything. Everything responds fine using a terminal program.
UCCM-P > system:status?
090-03861-03 serial number W561020383 firmware ver 1.0.0.2-01 LINK mode
Reference Status __________________________ Reference Outputs _______________
Ref 8KHz 0: [LOS]
TFOM 9 FFOM 3
UCCM-P Status[OCXO WARM]
>> GPS: [no ref]
ACQUISITION .............................................. [ GPS 1PPS Invalid ]
Tracking: 0 ____ Not Tracking: 0 ________ Time ____________________________
GPS 00:27:45 [?] 06 JAN 1980
GPS Invalid: GPS rcvr failed
ANT DLY +0.000E+00
Position ________________________
MODE Survey: 0% complete
Suspended: no track data
INIT LAT 0:00:00.000
INIT LON 0:00:00.000
INIT HGT +0.00 m (GPS)
ELEV MASK 0 deg
UCCM-P > posstatus
1/6/1980 00:35:46
Position : LAT( LON( H(0.00 m MSL)
Geometry : PDOP(0.0) HDOP(0.0) VDOP(0.0)
Channel Status
num of visible sats > 0
num of sats tracked > 0
------ Receiver Channel State ------
CH 0 > SateID(0) TrackMode(code search) SigValue(0)
CH 1 > SateID(0) TrackMode(code search) SigValue(0)
CH 2 > SateID(0) TrackMode(code search) SigValue(0)
CH 3 > SateID(0) TrackMode(code search) SigValue(0)
CH 4 > SateID(0) TrackMode(code search) SigValue(0)
CH 5 > SateID(0) TrackMode(code search) SigValue(0)
CH 6 > SateID(0) TrackMode(code search) SigValue(0)
CH 7 > SateID(0) TrackMode(code search) SigValue(0)
CH 8 > SateID(0) TrackMode(code search) SigValue(0)
CH 9 > SateID(0) TrackMode(code search) SigValue(0)
CH 10 > SateID(0) TrackMode(code search) SigValue(0)
CH 11 > SateID(0) TrackMode(code search) SigValue(0)
Rcvr Status(0) :
Antenna Voltage: 4637 mV, Antenna Current: 17 mA
UCCM-P > status
- UCCM Slot STATE -
1-1. #Now ACTIVE STATUS ---------------- [OCXO Warm]
1-2. #Before ACTIVE STATUS ------------- [Wait for GPS]
2-1. #Reference Clock Operation -------- [Not Used]
2-2. #Current Reference Type ----------- [LINK]
2-3. #Current Select Reference --------- [LINK0]
2-4. #Current Reference Status --------- [NOT SELECTED]
#GPS STATUS ----------------------- [Unavailable]
#Priority Level ------------------- [LINK > GPS]
#ALARM STATUS
#H/W FAIL ---------- [ GPS_COMM ]
#Bad Quality ------- [ LINK ]
3-1. PLL STATUS ------------------------ [Enable]
3-2. Current: PLL MODE ----------------- [OFFSET OBSERVATION MODE]
Command Complete
UCCM-P > GPS:SATellite:TRACking?
"Data corrupt or stale"
UCCM-P >
UCCM-P > DIAGnostic:LOG:READ:ALL?
Log status: 4 entries
L1:1980-01-06 00:27:05:Log cleared
L2:1980-01-06 00:27:05:SYST:PRESET performed
L3:1980-01-06 00:00:02:Power On
L4:1980-01-06 00:00:17:GPS Engine Alarm
Command Complete
UCCM-P >
