Author Topic: A look at my Symmetricom GPSDO / 10MHz reference (OCXO + Furuno receiver)  (Read 296106 times)
texaspyro and 1 Guest are viewing this topic.
Offline uski
Hi there !
I wanted to share the latest addition to my lab, a GPSDO :)
First I acquired a surplus used Symmetricom GPSDO PCB off eBay.
Had to buy the corresponding pigtails separately.
The board had a oily and smelly (organic solvent ?) liquid on it so I had to wash it with IPA and let it dry... the wonders of Chinese surplus parts...
Then I made a little case using a Hammond box :
I mounted the PCB with adhesive stand-offs :
The PCB sits at the top of the box because I put the adhesive feets on the removable panel - not sure if it's wise as I don't know if the adhesive will be strong enough. If I have issues I'll revert the labels and everything.
There is a 1 PPS and a 10 MHz output, GPS antenna input, and a 5V 3A power supply input, all on the back :
I moved the status LEDs which were on the PCB to the front panel ; there are two switches that I didn't move as their purpose is not fully understood and they don't seem to be needed for operation.
(I think I know what the RST switch does... but if anyone knows what the MACT switch does, let me know !)
These units seem very similar to various other GPSDOs I've seen used in the time-nuts community.
The GPS receiver is a Furuno GT-8031 module and a +5VDC bias is provided at the antenna port.
It is a 16-channel GPS timing module that supports T-RAIM and SBAS, not the latest generation but not as old as the modules used in many other GPSDOs.
This particular GPSDO unit has been first powered on in 2009 or 2011 (can't remember - logs have since been cleared) so it's pretty recent.
There is a console port (RS232 levels, and it's possible to tap into 3.3V signals before the level shifter chip, some cousin of MAX3232) which I connected to a DB9 port for diagnosis, I didn't make a hole for it yet since I'm not sure I'll keep it a DB9 or I'll put an integrated RS232-to-USB converter or even a small LCD with an arduino or similar, showing basic status information. But the LEDs are mostly enough.
So while I decide what to do with the console, I made a little adapter that I can use for initial setup and testing :
The features are decent, for instance the unit will generate an alarm (and light up the corresponding LED) if the GPS antenna is disconnected so I guess it does a bit of self-monitoring.
If it goes into holdover for too long (for instance, something is jamming the GPS signals but the antenna is still there), then it will generate an alarm too. I think the time it waits before setting an alarm can be changed.
Settings are 57600 8N1 no flow control and the commands look like SCPI.
Sending a question mark ? then pressing ENTER gives a list of the supported commands :
UCCM-P > ?
*IDN?
ALARm:HARDware?
ALARm:OPERation?
DIAGnostic:OUTPut ON|OFF
OUTPut:ACTive:ENABle
OUTPut:ACTive:DISable
OUTPut:ACTive:HOLDover:DURation:THReshold <seconds>
OUTPut:ACTive:HOLDover:DURation:THReshold?
OUTPut:INACTive
OUTPut:INACTive?
OUTPut:STATe?
SYNChronization:HOLDover:DURation:STATus:THReshold <seconds>
SYSTem:PRESet
SYNChronization:TFOMerit?
LED:GPSLock?
SYNChronization:FFOMerit?
GPS:POSition N or S,<deg>,<min>,<sec>,E or W,<deg>,<min>,<sec>,<height>
GPS:POSition?
GPS:POSition:HOLD:LAST?
GPS:REFerence:ADELay <numeric value>
GPS:REFerence:ADELay?
GPS:SATellite:TRACking:COUNt?
GPS:SATellite:TRACking?
DIAGnostic:ROSCillator:EFControl:RELative?
SYNChronization:TINTerval?
DIAGnostic:LOG:READ:ALL?
DIAGnostic:LOG:CLEar
SYSTem:PON
OUTPut:MODE?
SYSTem:STATus?
SYSTem:COMMunication:SERial1:BAUD 9600|19200|38400|57600
SYSTem:COMMunication:SERial1:BAUD?
SYSTem:COMMunication:SERial1:PRESet
SYSTem:COMMunication:SERial2:BAUD 9600|19200|38400|57600
SYSTem:COMMunication:SERial2:BAUD?
SYSTem:COMMunication:SERial2:PRESet
OUTPut:STANby:THReshold <seconds>
changeSN
SYNChronization:REFerence:ENABLE LINK|GPS
SYNChronization:REFerence:DISABLE LINK|GPS
SYNChronization:REFerence:ENABLE?
STATus
POSSTATus
TOD EN|DI
TIME:STRing?
REFerence:TYPE GPS|LINK
REFerence:TYPE?
PULLINRANGE 0|1|2|...|254|255
PULLINRNAGE?
DIAGnostic:LOOP?
DIAGnostic:ROSCillator:EFControl:DATA GPS|<value>
DIAGnostic:ROSCillator:EFControl:DATA?
OUTPut:TP:SELection PP1S|PP2S
OUTPut:TP:SELection?
GPSystem:SATellite:TRACking:EMANgle <degrees>
GPSystem:SATellite:TRACking:EMANgle?
DIAGnostic:TCODe:STATus:AMASk
DIAGnostic:TCODe:STATus:OMASk
DIAGnostic:TCODe:ERRor:AMASk
DIAGnostic:TCODe:ERRor:OMASk
DIAGnostic:HOLDover:DELay
DIAGnostic:HOLDover:DELay?
GPS:SATellite:TRACking:IGNore <PRN>, ...,<PRN>
GPS:SATellite:TRACking:IGNore?
GPS:SATellite:TRACking:INCLude <PRN>, ...,<PRN>
GPS:SATellite:TRACking:INCLude?
GPS:SATellite:TRACking:<select>:ALL
Command Complete
UCCM-P >
The prompt is UCCM-P>
The identification is (I blanked the last 4 digits of the serial) :
UCCM-P > *IDN?
Symmetricom,090-03861-03,W56094xxxx,1.0.0.2-01
Command Complete
I believe these were used in GSM/UMTS/CDMA base stations. There was a log in my unit, latest GPS fix was located at the top of a high building in Japan.
At bootup it goes through several states :
OCXO WARMUP
OCXO WARM
ACTIVE
The ACT LED corresponds to the PLL lock :
Green solid : PLL unlocked
Green flashing slowly : PLL locking ("adjusting freq" then "syncing")
Green flashing fast : PLL locked to GPS
While the PLL locks I can see the frequency change slightly on the output.
In parallel, at power on, the receiver starts doing an initial GPS survey by averaging the GPS positions, takes 2 hours to finish and needs good GPS signal quality.
If GPS signal quality gets too low (low elevation or not enough sats in view), the survey will be paused and will resume later.
Boot prompt is :
Symmetricom Boot Code ver. 1.01.01
Press Enter to go to boot
Image1: [1.0.0.2] [454535 bytes] [valid checksum:0x20AFA24] [timestamp:3]
Image2: [1.0.0.1] [454535 bytes] [valid checksum:0x2142B89] [timestamp:2]
Loading Image1
UCCM-P >
There are a few status commands :
UCCM-P > SYST:STAT?
090-03861-03   serial number W56094xxxx   firmware ver 1.0.0.2-01     LINK mode
Reference Status __________________________   Reference Outputs _______________
   Ref 8KHz 0: [LOS]
                                              TFOM     2             FFOM     0
                                              UCCM-P Status[ACTIVE]
>> GPS: [phase:  2.77e-08]
ACQUISITION ................................................ [ GPS 1PPS Valid ]
Tracking: 10 ____   Not Tracking: 1 ________   Time ____________________________
PRN  El  Az  C/N   PRN  El  Az                GPS      19:08:57     24 NOV 2015
  5  22  87   36    10  Not OK                GPS      Synchronized to UTC
 13  53  56   37                              ANT DLY  +0.000E+00
 15  83 160   42                              Position ________________________
 18  36 282   38                              MODE     Hold
 20  73  60   40
 21  56 295   39                              LAT      N  45:29:xx.xxx
 24  16 162   34                              LON      W  73:33:xx.xxx
 27   5 331   32                              HGT               +84.80 m  (MSL)
 29  20 212   35
 30  10  34   33
ELEV MASK  5 deg
Command Complete
And that one too :
UCCM-P > STATus
                 - UCCM Slot STATE -
1-1. #Now ACTIVE STATUS ---------------- [Master]
1-2. #Before ACTIVE STATUS ------------- [Master Holdover]
2-1. #Reference Clock Operation -------- [Not Used]
2-2. #Current Reference Type ----------- [LINK]
2-3. #Current Select Reference --------- [GPS 1PPS]
2-4. #Current Reference Status --------- [Good Accuracy & Stable]
     #GPS STATUS ----------------------- [Available]
     #Priority Level ------------------- [LINK > GPS]
     #ALARM STATUS
     #H/W FAIL ---------- [ LINK ]
3-1. PLL STATUS ------------------------ [Enable]
3-2. Current: PLL MODE ----------------- [NORMAL 2 MODE]
Command Complete
It's interesting, it says "UCCM slot" so UCCM is probably the product name, and it was used in slots, which apparently could be linked together for redundancy, probably through the ribbon cable connector which can be seen on the PCB picture above.
There is also a GPS-specific status command :
UCCM-P > POSSTATus
11/24/2015 19:11:26
 Position : LAT(N 45:29:xx.xxx) LON(W 73:33:xx.xxx) H(84.80 m MSL)
 Geometry : PDOP(0.0) HDOP(0.0) VDOP(0.0)
 Channel Status
   num of visible sats > 11
   num of sats tracked > 10
   ------ Receiver Channel State ------
     CH 0 >  SateID(5) TrackMode(pos avail) SigValue(39)
     CH 1 >  SateID(13) TrackMode(pos avail) SigValue(40)
     CH 2 >  SateID(15) TrackMode(pos avail) SigValue(44)
     CH 3 >  SateID(18) TrackMode(pos avail) SigValue(41)
     CH 4 >  SateID(20) TrackMode(pos avail) SigValue(41)
     CH 5 >  SateID(21) TrackMode(pos avail) SigValue(40)
     CH 6 >  SateID(24) TrackMode(pos avail) SigValue(35)
     CH 7 >  SateID(27) TrackMode(pos avail) SigValue(36)
     CH 8 >  SateID(29) TrackMode(pos avail) SigValue(36)
     CH 9 >  SateID(30) TrackMode(pos avail) SigValue(33)
     CH 10 >  SateID(0) TrackMode(code search) SigValue(0)
     CH 11 >  SateID(0) TrackMode(code search) SigValue(0)
  Rcvr Status(2) :
  Antenna Voltage: 4794 mV,  Antenna Current: 10 mA
Command Complete
And the best one, the timing loop status :
UCCM-P > DIAGnostic:LOOP?
11/24/2015 19:12:19
   LOS      MEAS       NCO STATUS WEIGHT PBUC FBUC DBUC LBUC IBUC G  M TC
 0:  1  0.000e+00  0.000e+00 0x07AC   0   700  700    0    0    2  2  4 29
 1:  1  0.000e+00  0.000e+00 0x068C   0   700  700    0    0    0  2 14 226
GPS: 0 -3.037e-08 -7.041e-09 0x0000   1  ---- 1000 1000 ---- ----  3  6 31
freq cor  = -7.041106e-09
phase cor = -2.000000e-11
gps phase = 2.033333e-08
temp cor  = -3.383123e-11
Command Complete
If anybody can help me make sense of that data, please feel free to do so ! I understand 0 and 1 are probably inputs to daisy chain the units so I'm not very interested in these, but what's MEAS (measured phase noise ??), NCO (??), and the TFOM and FFOM saw in the first status command above ? Any other information ? Anyone knows what kind of precision I can expect from that kind of GPSDO ? I don't care about alignment of the frequency output and PPS output to the UTC second but I care about frequency drifts (which should be 0 long term, but what about short term ?).
It's definitely a very good and useful lab instrument, I used it to calibrate a HP 5334A counter. Build one too ! :)
« Last Edit: November 25, 2015, 04:58:46 am by uski »
The following users thanked this post: cdev, ironcurtain, Confucian
Online TheSteve
  • Living the Dream
Re: A look at my Symmetricom GPSDO (OCXO + Furuno receiver)
« Reply #1 on: November 24, 2015, 09:55:33 pm »
Excellent post - your box is very similar to mine but I used the Trimble equivalent model. Mine is also mounted inside a Hammond box.
I used the proper connector pigtails with mine but for someone looking to save even more money you could solder the coax direct to the bottom of the Trimble board and then direct to chassis mount BNC etc connectors.
VE7FM
Offline Brainbox
Re: A look at my Symmetricom GPSDO / 10MHz reference (OCXO + Furuno receiver)
« Reply #2 on: November 29, 2015, 08:31:53 am »
First, my name is Ko and I am new in this group.
I bought one of those Trimble boards from EBay and was looking for some information about this device.
A first inspection of the board learned me that one capacitor came lose frome the board and was only connected by one leg.
The seller made his excuses and I became a partial refund for this.
Because of the complete lack of info from the seller I had to find out everything by myself.
Thanks to Your postings I got it to work  and now building a nice enclosure around it.
There it was that someting strange showed up.
Without the case it works fine, but build into the metal housing the ouput changed dramatically.
Taking it out of  the enclosure output changed to normal again.
I found that the metal pads around the four mounting holes are not all connected to ground, but only two of them.
Now I mounted the two other pads with nylon screws to isolate them and that seems to solve the problem.
To @Uski; I found that the MACT switch forces it to generate an output, even with no antenna attched.
So it seems to mean Manual_Activate and shows a alternating red and green activity LED by doing this.
I, who know nothing
Offline Theboel
  • Country: id
« Reply #3 on: December 01, 2015, 11:01:04 pm »
Hello,
do you have manual for your symetricom UCCM board ?
the price is very appealing but I like to know if it posible to extract NMEA data from this board.
Thank You
Online Vgkid
« Reply #4 on: December 01, 2015, 11:44:58 pm »
Thanks for the post, I'm contemplating buying one of these modules. What is the main connector pinout?
Online TheSteve
  • Living the Dream
« Reply #5 on: December 02, 2015, 05:06:42 am »
I have not found or seen any official documentation for this board or the Trimble equivalents.(you can google for Trimble 63090 or 73090)
You can enable a once per second string but it is hex data string, not NMEA data.
As Brainbox mentioned the 4 mounting holes are not all ground - one of them is connected to the 5 volt regulator.
The M-act button does manually enable the 10 MHz output even if no GPS lock has been achieved. In the case of the my Trimble which has been running for months constantly it is very accurate in the short term from a cold start. With no GPS connected after the oven is warm it is currently within 4 mHz of proper 10 MHz. So if you had to take the unit out of the lab and just needed a quick reference it would do quite nicely even without GPS lock.
VE7FM
Offline uski
« Reply #6 on: December 03, 2015, 06:07:48 am »
Hi everybody !
Sorry for the lack of replies from me, I didn't see I wasn't subscribed to the thread !
I had a similar problem. Those boards are probably scrap yard pulls and have probably seen pretty bad days.
It's a very good thing to inspect them before powering them up and to watch out for magic smoke at first power up (damage can often be limited if power is turned off quickly in case of apparent issue).
Glad it helped, let me know if you have more specific questions :)
I used adhesive nylon standoffs everywhere so I didn't know that. Thank for the info, it should help others :)
Great, thanks !
Hello,
Thank You
The official documentation of the Furuno receiver used shows that it uses a "NMEA like" protocol. That's probably standard NMEA with additional proprietary messages.
What application do you have in mind ? If you want to use it as a GPS receiver, I'd say, just get a dedicated GPS receiver. Unless you need a low jitter PPS output, you can get a cheap GPS receiver on eBay. If you want a more precise PPS output, then yes, you need a timing GPS receiver like this one. There is the good uBlox LEA-6T for this, or even the newer (multi-GNSS) LEA-8T.
I have absolutely no idea :D I didn't connect anything to it. I connected the +5V input to the fuse directly and to ground, I guessed their location from looking at the power supply layout.
The colorful ribbon you see if for the LEDs, I soldered the wires on the back of the PCB to each LED. The ribbon is not connected to the main flex connector which has tens of pins.
The power supply is also connected to the main ribbon connector.
There are definitely more possible options when using the main connector, specifically linking several of these boards together to get redundancy, but you'd have to find the pinout.
If you want to try to contact Symmetricom to get the info, feel free to do it and share the result ! :)
That's a pretty good info. I guess it stores OCXO calibration data in some kind of NVM to make it ready for a cold start.
I used my GPSDO today to calibrate other equipment. It's really a useful piece of hardware.
I like your case - you're right it looks pretty similar to mine ! :)
Online TheSteve
  • Living the Dream
« Reply #7 on: December 03, 2015, 06:16:25 am »
Ran my Trimble for 24 hours without GPS - it did very well and was still 4 mHz or less from my other GPS reference. In fact when I connected the GPS antenna a much larger error was introduced for quite a while as it re-synchronized. If anything the OCXO is over-controlled by software and made less stable in the short term. This isn't generally an issue as I leave it running 24/7. I've wanted to order the Symmetricom version to compare them for quite some time but haven't found an extra 50 dollars to throw at it as I already have two GPSDO's. When I bought my Trimble they were under 50 dollars shipped on ebay - for now the Symmetricom at under 50 is the best buy.
VE7FM
Offline Deathwish
  • Country: wales
« Reply #8 on: December 03, 2015, 06:32:35 am »
I'm still waiting for my symetricon to arrive, I think it lost its GPS bearings between China and the UK
Electrons are typically male, always looking for any hole to get into.
trying to strangle someone who talks out of their rectal cavity will fail, they can still breath.
God hates North Wales, he has put my home address on the blacklist of all couriers with instructions to divert all parcels.
Offline Deathwish
  • Country: wales
Offline f1rmb
« Reply #10 on: December 03, 2015, 08:36:55 pm »
    I'm also building a GPSDO using this Symmetricom card.
Today I probed the Furuno pins to get the NMEA frames (Pin#2, next to the square pad one). So that's great.
But, since I want to use a GPS display module developed by another Ham (F4CTZ: http://www.f4ctz.fr/?page_id=692), but the little problem with this is that NMEA frames doesn't have checksum field.
I've currently modified the source code of the GPS display module to handle that kind of frames, but I have to wait for a friend to reflash the PIC.
Cheers.
Daniel
Offline Macbeth
« Reply #11 on: December 10, 2015, 09:20:52 pm »
Just to let us Symmetricon fanboys know, the MACT button does indeed enable the 10MHz output without a GPS signal. This is also possible using the serial command
Online PA0PBZ
« Reply #12 on: December 11, 2015, 08:04:04 pm »
Received mine yesterday, same seller I guess because it also included the oil  ;)
http://www.ebay.com/itm/121761130751
Also ordered this antenna from the same seller, it works ok:
http://www.ebay.com/itm/111734469938
And a handful of pigtails from here:
http://www.ebay.com/itm/281313869844
Looks like it lived on this building from October 2011 to at least (last log entry) April 2014:
https://www.google.com/maps/@35.361216,139.6222302,42m/data=!3m1!1e3
I wonder if the seller did test these, there's no evidence in the log that it was ever powered on between the building and my house.
L485:1980-01-06 00:00:02:Power On
L486:1980-01-06 00:00:36:Survey mode started
L487:1980-01-06 00:01:48:Time set to GPS
L488:2014-04-24 01:45:50:Time set to GPS
L489:2014-04-24 01:49:04:GPS lock started
L490:2014-04-24 03:44:48:Position hold mode started
L491:2014-04-24 03:44:48:Lat: N,+35,+21,+40.5
L492:2014-04-24 03:44:48:Long: E,+139,+37,+20.4
L493:2014-04-24 03:44:48:Height: +67.5
L494:1980-01-06 00:00:02:Power On
L496:1980-01-06 00:00:36:Survey mode started
L497:1980-01-06 00:07:54:Time set to GPS
L498:2015-12-11 19:10:14:Time set to GPS
L499:2015-12-11 19:11:11:GPS lock started
Initial current at 5V was 1.8A, dropping to 0.8A after the OCXO warms up.
Now to find a nice spot for the antenna and put it in a box...
Edit: The forum doesn't like links with a ! in it, so if you want to see the building copy the full link to your browser or click 'earth'.
« Last Edit: December 11, 2015, 08:06:33 pm by PA0PBZ »
Offline Deathwish
  • Country: wales
« Reply #13 on: December 12, 2015, 09:09:22 am »
Mine is well overdue from him, ordered the same antenna from another seller, so glad to hear it works ok.
Offline davebb
« Reply #14 on: December 12, 2015, 11:02:39 pm »
Hi I have just ordered the symetricon and the trimble gpsdo from the same seller,i hope they work ok,
I am going to lock my kenwood ts-2000 and my 4 meter transverter and test gear with then,
how long do these take to settle at 10.000000MHZ,and what is the max voltage it can be run from?
what is the sensitivity like from the gps rx,and what number of sats do you need to be receiving for good 10mhz stability,
what size is the unit so I can start looking for a box to fit it in,
Thanks Dave 2E0DMB
Offline Macbeth
« Reply #15 on: December 12, 2015, 11:40:48 pm »
The Symmetricom and the Trimble versions of these should run at >5V-5.5V with a 2A supply no problem, PSU lead losses accounted for. Don't go too much over 5V as the supply is directly sent (minus a diode drop) to the external antenna, which are usually 3-5V.
The Symmetricom has a 12V OCXO and uses a TI PTN4050C boost converter while I understand the Trimble uses a 5V OCXO so doesn't need this.
My Symmetricom boost converter was DOA, as was the missing MCX antenna socket and the broken MACT switch.
The seller gave me the runaround and eventually pretended to send me a replacement board out and try and get me to "wait for it" one week after the ebay dispute timeout period. Of course with my simple notification that I would involve ebay he refunded me at the 11th hour.
I'm now using a cheap XL6009 instead. There are some other issues with starting this Symmetricom board with less than 1.7A too...
« Last Edit: December 12, 2015, 11:43:09 pm by Macbeth »
Offline davebb
« Reply #16 on: December 13, 2015, 11:14:41 am »
Hi thanks for the info,i will post when I receive them,
Thanks Dave 2E0DMB
Offline davebb
« Reply #17 on: December 13, 2015, 03:07:09 pm »
Offline f1rmb
Regular Contributor
Country: fr
View Profile
 Personal Message (Offline)
« Reply #10 on: December 04, 2015, 07:36:55 AM »
Cheers.
Daniel
Hi Daniel
Could you please The modified Hex code/File as I would like to build this display,
you say the output is on pin 2 is that in rs232 or TTL level?
Thanks Dave 2E0DMB
Offline f1rmb
« Reply #18 on: December 13, 2015, 03:23:52 pm »
Hi Daniel
Thanks Dave 2E0DMB
Yeah, sure.
The level is TTL.
On the display module, you have to change two components:
T1 from 2N2222 to MMBT2907 (or equivalent), and the base resistor R3, from 10k to 4k7.
Cheers.
Daniel
Offline f1rmb
Offline davebb
« Reply #21 on: December 13, 2015, 04:35:24 pm »
Hi Daniel
Thanks for that,I will Wait until I have the unit,
have you made your display?
would I be able to use a different display as I would like to make it on vero board,
This is one of the things I am going to use the 10mhz ref for,  http://www.vk3hz.net/XRef/XRef_Home.html
I have the one for the kenwood ts-2000 and I had him make me a 10mhz to 42mhz unit with a tcxo for when the 10mhz ref is not plugged in for my 4 meter transverter, the units took about 1 week to arrive in the uk
Thanks Dave 2E0DMB
Offline f1rmb
« Reply #22 on: December 13, 2015, 04:38:48 pm »
Hi Dave,
 No, I didn't etched the PCB, with 2 Ham friends we ordered the last 3 kits from F4CTZ some time ago.
Maybe you could ask him if he have some new kits available.
Cheers.
Daniel
« Last Edit: December 13, 2015, 04:40:32 pm by f1rmb »
Offline Macbeth
« Reply #23 on: December 13, 2015, 05:54:24 pm »
...and the TFOM and FFOM saw in the first status command above ? Any other information ?
I just found this one.
TFOM (Time Figure of Merit) is the accuracy of the 1 PPS signal, with 0 < 1ns, 1= 1 to 10 ns, 2 = 10 to 100 ns, 3 = 100ns to 1us, ... 9 > 1ms
FFOM (Frequency Figure of Merit) is the stability of the 10MHz signal. 0 = PLL stable, 1 = stabilizing, 2 = holdover, 3 = unlocked (do not use as 10MHz out of spec)
You can use the commands SYNC:TFOM? and SYNC:FFOM? to get a description of the current state.
e.g.
UCCM-P > sync:tfom?
10-100 ns
Command Complete
UCCM-P > sync:ffom?
PLL stabilized
Command Complete
I'm trying to find other stuff and can't find the manual for this particular unit, but other symmetricom and HP GPSDO manuals seem to have similar information in them.
Offline davebb
« Reply #24 on: December 13, 2015, 07:25:55 pm »
Hi I did email F4CTZ: http://www.f4ctz.fr/?page_id=692),
about the nmea v2 gps display kit, and I got a reply from him saying that if 10 or more people want to buy the display  kit he will produce the kit again,i have asked for the price of the kit
I will post when I get the info
Thanks Dave 2E0DMB
