Author Topic: Light controller legalities and certification  (Read 3688 times)
Offline electron_misfireTopic starter
« on: November 18, 2014, 07:19:11 am »
Hi guys,
So I'm building a light controller that I hope to sell (it uses a triac dimming circuit) and I'm wondering whether it's legal to sell this without certification and if I do need certification, how to get it cheaply.
Sent from my iPhone using Tapatalk
Offline HackedFridgeMagnet
Re: Light controller legalities and certification
« Reply #1 on: November 18, 2014, 07:37:29 am »
If you want to sell it within Australia, No (that was easy).
I don't think it is possible to do it cheaply. The cheapest would be at a wild guess maybe $4000.
It would be classified as a declared article and as such needs safety testing.
It would also need EMI testing.
One testing place should be able to do both lots of tests.
First thing you need to do is work out what tests they do exactly and make sure it passes them all even before you even send samples to them.
It's called pre-compliance testing.
« Reply #2 on: November 19, 2014, 12:30:55 am »
Hi, ok I guess I'll have to think about this more. Do you know what standards I'll have to apply for I want to sell this in Australia, the USA and Europe
« Last Edit: November 19, 2014, 12:47:56 am by electron_misfire »
Offline Kjelt
« Reply #3 on: November 19, 2014, 09:31:36 am »
You need to provide more details, I think if you make it DC operated and double isolated (so you have a third party certified external power supply) you have less hassle than if you make it directly mains powered. Is it a mains lighting controller, or a Led lighting DC controller, what is it?
Not to ruin your dreams but there are a lot of lighting companies selling controllers out there, are you sure you want to invest in certification without knowing for sure you can at least break even on it?
Some companies/certifications I know of:  Europe: KemaKeur, TuV   USA: UL
look on a global powersupply connector to see what kinds of certifications it has.
« Last Edit: November 19, 2014, 09:33:13 am by Kjelt »
