I would like to build a device that has two USB inputs, which are used for power only (no data). The device should get power if either or both ports have hosts plugged into them. I assume I need to isolate the hosts' grounds and +5V from each other.
There are modules available (e.g.
http://www.recom-power.com/pdf/Econoline/RM.pdf) which apparently convert DC to AC, put it through a transformer, then rectify it back to DC. It looks as if I could have one on each port. My concern is, what happens if I tie the outputs of these together? The USB inputs are still isolated, so that's fine. But will +5V at the output damage something if there's no +5V at the input? Nothing in the data sheet seems to say. If the output is a typical rectifier + capacitor, everything should be fine. What if there's a regulator too? Or is it possible that the output stage isn't merely a rectifier and cap?
Alternatively, is there an better way to do this?
(My application is that I have a USB-controlled power strip: when there's +5V at the USB port, it turns on AC power. I want the power strip to turn on if either a Blu-ray player or a PS/3 is turned on - they both have USB ports that only go live when the device is on. So I need to "or" the +5V coming from the Blu-ray and the PS/3 into the power strip's single input.)
Thank you,
Bob
