Author Topic: A problem about check if my PSU work?(Use PC817)  (Read 987 times)
Offline China NewBoyTopic starter
  • Country: cn
« on: November 08, 2019, 02:03:54 am »
i have made a switching-mode power and i want my Atmega16 read if my power work
in the current scheme,i use the optocoupler pc817 which is connect to the PWM chip(ob2269)’s Vdd.
but, i meet some problems , when the PC817 is connected to the VCC,the PWM chip dont work at all,because its Vin stay at 4.7V (the typical work volt is 19V).           if the PC817 is NOT connected, i found the PSU work.
i wonder what caused this problem.
Here ↓ is my scheme pdf and  some printscreen pics
« Last Edit: November 08, 2019, 02:57:51 am by China NewBoy »
Offline xavier60
Re: A problem about check if my PSU work?(Use PC817)
« Reply #1 on: November 08, 2019, 02:35:08 am »
The startup current is very low. Vdd must have no load on it to start.
Does the opto need to be driven from the primary side?
HP 54645A dso, Fluke 87V dmm,  Agilent U8002A psu,  FY6600 function gen,  Brymen BM857S, HAKKO FM-204, New! HAKKO FX-971.
The following users thanked this post: China NewBoy
  • Country: cn
« Reply #2 on: November 08, 2019, 02:45:45 am »
im considering put my opto on the secondary side ,
i will do some experiments on the breadboard to figure out if it can work on secondary side
here ↓ is my new plan
  • Country: cn
« Reply #3 on: November 08, 2019, 02:55:50 am »
it can work on the secondary side now! ;D ;D ;D
but im  still wondering ,why adding load to VDD could impact the volt of Vin?
Offline xavier60
« Reply #4 on: November 08, 2019, 03:02:05 am »
Before the power supply starts, the only available current is via the VIN pin.
  • Country: cn
« Reply #5 on: November 08, 2019, 03:19:27 am »
im still wondering about why the VDD's LOAD can lead to the Vin's volt drop...maybe just becasue im still a newbie and i know nothing about the chip...
but thank you really.the problem is solved now.
