Author Topic: A problem about my switch mode Power supply  (Read 525 times)
Offline China NewBoyTopic starter
  • Country: cn
« on: November 03, 2019, 11:56:06 am »
 i made a 24V switch mode power and it is suppoed to output the current of 2A ,but ,after i did some experiments,i found the Volt drop down to 22V when the LOAD is 12ohm. (there is weird sound -ZiZi)  (pdf 's  left upon part is the power supply unit) ,i think the circuit around OPA or tl431 is the key ,however, i just cant adjust it properly.
my SchDoc Pdf
my PCB Doc
 hope the problem solved :-+
Offline Simon
  • Global Moderator
    • Simon's Electronics
Re: A problem about my switch mode Power supply
« Reply #1 on: November 03, 2019, 01:49:44 pm »
If you start another topic twice you will be banned! i hope that is clear enough for you.
