Author Topic: A problem about my switch mode Power supply  (Read 1863 times)
Offline China NewBoyTopic starter
  • Country: cn
« on: November 03, 2019, 05:12:52 am »
 :-// i made a 24V switch mode power and it is suppoed to output the current of 2A ,but ,after i did some experiments,i found the Volt drop down to 22V when the LOAD is 12ohm. (there is weird sound -ZiZi)  (pdf 's  left top part is the power supply)
My problem 's video :   https://www.youtube.com/watch?v=oZOkMZSDCR8&feature=youtu.be
« Last Edit: November 04, 2019, 02:08:57 pm by China NewBoy »
  • Country: cn
Re: A problem about my switch mode Power supply
« Reply #1 on: November 03, 2019, 05:18:05 am »
my SchDoc Pdf
« Last Edit: November 03, 2019, 05:26:20 am by China NewBoy »
  • Country: cn
« Reply #2 on: November 03, 2019, 05:20:24 am »
my PCB Doc , hope the problem solved :-+
  • Country: cn
« Reply #3 on: November 03, 2019, 11:42:52 am »
sorry,i forget to mention that the PSU part is in the left upon of the SCHDoc ,and i think the circuit around OPA or tl431 is the key ,however, i just cant adjust it properly.
Offline xavier60
« Reply #4 on: November 03, 2019, 01:22:51 pm »
I think R19 should connect to the rail being  regulated, 24V.
HP 54645A dso, Fluke 87V dmm,  Agilent U8002A psu,  FY6600 function gen,  Brymen BM857S, HAKKO FM-204, New! HAKKO FX-971.
The following users thanked this post: China NewBoy
  • Country: cn
« Reply #5 on: November 03, 2019, 02:18:48 pm »
it  is a  restrict current res  , the Res change the  volt is  r10 r12 ,and i think the problem is relate to the current loop because the volt is accuracy with no load or larger than 20ohm
Offline xavier60
« Reply #6 on: November 03, 2019, 02:38:57 pm »
Look for "slow lane" and "fast lane"
https://www.onsemi.com/pub/Collateral/TND381-D.PDF
  • Country: cn
« Reply #7 on: November 03, 2019, 02:53:39 pm »
thankyou for your book really, i found i know nothing about tl431...im so stupid...
Offline xavier60
« Reply #8 on: November 03, 2019, 02:53:46 pm »
Is there activity at the comparator output pins?
  • Country: cn
« Reply #9 on: November 03, 2019, 03:05:23 pm »
i measured by multimeter, it has output ,and i increase the r28 r31 several times.. and then the problem is still there .
after that i dont measure the amp anymore :-X  (in order to let the current limit larger i take r25 away)
« Last Edit: November 03, 2019, 03:08:52 pm by China NewBoy »
  • Country: cn
« Reply #10 on: November 03, 2019, 03:12:28 pm »
it is late in china, i will try to figure out your datesheet tomorrow.thank you for your reply
  • Country: cn
« Reply #11 on: November 04, 2019, 01:01:12 pm »
I increase the value of R19 to 2.7K and the output volt seems no difference.
« Last Edit: November 04, 2019, 01:09:58 pm by China NewBoy »
  • Country: cn
« Reply #12 on: November 04, 2019, 01:05:32 pm »
I increase the value of R19 to 2.7K and the output volt seems difference.
i think what casue my problem is the current checking loop is too sensitive.
« Last Edit: November 04, 2019, 01:09:22 pm by China NewBoy »
  • Country: cn
« Reply #13 on: November 04, 2019, 01:13:37 pm »
sorry about my typing mistake (lack a no.....)..sorry
  • Country: cn
Offline ocset
« Reply #15 on: November 16, 2019, 09:10:49 pm »
your transformer is not phased correctly for it to be a flyback.
(The  dots are in the wrong place)
  • Country: cn
« Reply #16 on: November 19, 2019, 10:36:20 am »
thank you , i knew that my sch have the transformer mistake but my PCB doc is not wrong .....just too lazy to correct the sch
  • Country: cn
« Reply #17 on: November 19, 2019, 10:40:06 am »
and the problem have been solved ,its c2_cha
 ..... my stupid  mistake, i take a 1uf cap to solder on c2_cha's place.
and it cause the  feedback volt too low
« Last Edit: November 19, 2019, 10:41:37 am by China NewBoy »
