Anyway as the title states, I'm looking for some more information on how these work/can be used.
I pulled a "F5LC20U" out of a computer power supply a long time ago, but it's sat dormant in my parts box until now(my interest in electronics has been rekindled). Looking at the side of the packaging, it appears to be 2 diodes mounted end to end(presumably output side facing inwards).
Now that got my thinking; could you hook up 2 separate power supply modules(positive rails, I assume), and have them combine in this component? The idea being is there could be 2 separate 5V rails but if you ignore those 2 ports and plug straight into the middle port(assume this example has 3 ports), could you get 5V with increased amperage(or 10V with halved amperage, I forget which way it works). The 2 separate would work fine until load is placed on the middle port(assuming no connection in the others).
I wonder if there is a reverse of this, 2 diodes facing away from each other?
Just some noob theories, if anyone can enlighten me, that would be great. Worst case I'll probably just get some 1N4004's and try the idea anyway.
Thanks
