Hi everyone,
I'm building a lithium battery powered device driving a bunch of 12V motors at around max 3A, but now wondering if I made the right choices. In my view there are two options:
1. Parallel cells:
- Each cell gets a separate battery charger ICa boost converter. Correct voltages are easily handled by standard lithium charger ICs
- Boost converter to go to 12V for motors
- 5V power supply
2. Serial cells
- 3 cells in serial. 12.6V for charging and 11.1V when discharging
- Buck converter from power supply to 12.6V with current limit to protect charging.
- >13V power supply
So far I went with option 2, but I noticed that I'm not that good at making a reliable buck converter, some of them fail to supply enough current. Also the feedback voltage divider needs 0.1% resistors to have enough accuracy and those can be expensive/harder to source. Should I have gone with 1 instead?
For reference this is what my current buck converter schematic looks like
