Author Topic: Where to find these heat conducting DPAK blocks ?  (Read 1041 times)
Offline CookieMonsterTopic starter
« on: December 07, 2021, 06:23:21 pm »
Hi Guys,
I recently saw these heat conducting blocks surface-mounted above an SMT DPAK package.
It appears to be a tin tinned copper material - the dimensions are 12x6x4.5mm
I already did some research online, but could find anything like these.
Does anyone know how these are called or where they can be sourced ?
Thanks !
Offline Gyro
Re: Where to find these heat conducting DPAK blocks ?
« Reply #1 on: December 07, 2021, 06:34:18 pm »
I haven't seen those before, it's possible that they are custom. They look to be designed to add thermal mass for pulse operation rather than efficient heatsinking.
SMD heatsinks are common however, they might work, depending on your needs. eg... https://uk.rs-online.com/web/p/heatsinks/7124217/
Best Regards, Chris
The following users thanked this post: Pineapple Dan
« Reply #2 on: December 07, 2021, 06:36:39 pm »
Thanks for your reply !
Those are the only things I've found too.
The point for the ones shown is, that they couple to an aluminium plate to which the PCB is mounted.
Offline strawberry
  • Country: lv
« Reply #3 on: December 07, 2021, 06:48:08 pm »
PCB vias and 2mm thick thermal pad
Offline Gyro
« Reply #4 on: December 07, 2021, 07:09:57 pm »
Ah yes, that makes more sense.
It looks like a challenge in mechanical tolerancing. Turning it around, what about blocks mounted on the Aluminium plate which make contact with either the exposed PCB copper area, or the D-PAKs themselves. Either way, you probably need thermal pads, as strawberry says, to take up mechanical variations and ensure decent contact [Edit: and electrical insulation].
Best Regards, Chris
Offline Someone
    • send complaints here
« Reply #5 on: December 07, 2021, 08:48:29 pm »
What sort of volume? Nearest off the shelf part would be the SMD screw terminals. Wurth do those on tape for pick and place, say 7466303R
« Reply #6 on: December 07, 2021, 10:56:31 pm »
Thats how its done on the picture I posted. There is a pad that covers both the metal block and the DPAK.
Still, I do believe that this would provide a much better thermal conduction than just cooling the DPAK with such a pad.
Probably not enough to justify a custom part.
I wouldn't even know how to pull that off - even if my metal guy could make this part, the main challenge would probably be putting it in a reel to make it suitable for production.
Offline thm_w
  • Non-expert
« Reply #7 on: December 08, 2021, 01:24:51 am »
It doesn't need to go in a reel, can be in a waffle tray. But thats probably more custom work to be done.
https://www.youtube.com/watch?v=t8SidZ3wLvQ
Similar example is shown in this PDF: https://www.infineon.com/dgdl/Infineon-ApplicationNote_Package_DoubleDPAK_DDPAK-AN-v01_00-EN.pdf
What about machining that block into the case itself? Or having a epoxied/screwed in piece?
« Reply #8 on: December 08, 2021, 09:44:30 am »
Sure, that would work - but it can't compete with the simplicity and elegance of this solution  ;)
