Author Topic: Thermocouples shouldn't be difficult right?  (Read 1130 times)
Offline JonnyTopic starter
« on: January 05, 2018, 07:58:56 am »
Hey all. Let me tell you a tale of woe...
So my lovely jarcar supplied solder station is now obsolete after 7yrs and my iron failed so I thought I'd gamble on an iron of same spec, looks physically the same, but from a different station and swap the plug over. Well it was a 50/50 chance. The element is same rating so all good there. The thermocouple I wouldn't have thought would be anything special but it doesn't give an ouput. My old irons thermocouple has an increasing voltage and resistance with temp and puts out around 10mV @ approx 130degC. The new one puts out 0mV and has a fixed resistance of 54ohm. Of course the controller can't work with that.
What kinda thermocouple behaves like this? Or did I happen to purchase a factory dud iron that I can't return as it's now modified.
Yes I wired the plug correctly :)
Jonny
Offline Kleinstein
Re: Thermocouples shouldn't be difficult right?
« Reply #1 on: January 05, 2018, 08:10:43 am »
For a thermocouple 10 mV at 130 C is allready quite a lot of voltage. It might be a type E thermocouple.
https://en.wikipedia.org/wiki/Thermocouple#Nickel-alloy_thermocouples
Offline jeroen79
« Reply #2 on: January 05, 2018, 10:59:28 am »
Assumptions.
Post the brand and model of both stations so we may look things up.
The thermocouple I wouldn't have thought would be anything special but it doesn't give an output.
How do you know it is a thermocouple? It might be a thermistor.
If you could do some more extensive measurements of resistance and voltage over temperature we could say more about it.
What does it do at the operating temperatures? (350C)
Offline mikerj
« Reply #3 on: January 05, 2018, 01:16:44 pm »
A low resistance with zero voltage suggests it could be a platinum resistance thermometer.  If so it's not compatible with a thermocouple interface unfortunately.
« Reply #4 on: January 05, 2018, 09:48:07 pm »
I let it get stinking hot and resistance went to 150ohm, guess it's a thermister then. Was only a $30 gamble. Maybe I can modify the input circuit so this forms part of a resistor divider on the opamp input or something.....
Jonny
