Hi guys,
I've a problem where I've difficulties to find a solution.
A very simply circuit, an aesthetic (and functional) panel is composed by only:
- 200 5mm Water Clear - LEDs
- 50 resistor
- powered by 24v.
For a lot of reason, like mechanical, appearance and production, would be good to find an SMD alternative.
I found that conversion from Standard LED to SMD LED is difficult.
My LEDs have this characteristics:
- Between 17k-20k mcd, one color between 8k-10k mcd;
- Lens have about 20deg;
- 5mA aprox. on single LED.
Can't find a suitable, and low cost, SMD LED with same char. Do you have suggestions?
