Author Topic: UltraDMM Software Project  (Read 124886 times)
Offline Lightages
  • Canadian po
Re: UltraDMM Software Project
« Reply #250 on: May 12, 2015, 10:53:53 pm »
It runs on my Win7 x64 no problems. I cannot connect to anything because all my multimeters are at home and I won't be able to really test until the 15th at least.
Offline BThunderW
« Reply #251 on: May 12, 2015, 11:34:50 pm »
Got it. Looks like I missed one more Infragistics reference. Will post update shortly.
Hello.
The same here...
Win7Pro 64-bit full updated.
At first run there was an error displayed.
(See appended txt-file: Errors after first run)
Since then: UltraDMM.exe simply doesn´t start after permitting installation.
The eventvwr shows two errors.
(See appended txt-file: Errors since first run)
My eventvwr-log is unfortunatly in some parts in german.
Perhaps it is anyhow useful for you. At least I hope so.
Hartmut
Offline BThunderW
« Reply #252 on: May 19, 2015, 02:45:58 pm »
Sorry for the delay, been away on a short vacay. New update available.
http://www.ultradmm.com/release/wip/UltraDMM2.zip
Cheers,
Tom
Offline ProBang2
« Reply #253 on: May 19, 2015, 10:58:01 pm »
Success!     :clap: :clap:
The downloaded file starts without any problems direct from the unzipped folder.
Only a request for permission for executing the file appears (as expected).
No entry occured in the eventviewer.
Capturing data from an UT61E via USB works as good as in the "older" version.   :-+
Two little quirks (both in the Graph Gauge):
- The time-stamps at the bottom of the graph are automatically synchronized with the PC-time.
But not in the 24h format. It´s converted to the 12h format, without indicating "am" or "pm".
- Setting the background color to black makes the measurement values (printed along the graph) invisible.
Is there anything I can do for you?
Hartmut
Offline zerobrain
« Reply #254 on: May 21, 2015, 02:17:48 pm »
Thanks very much for the update.
I have two UT61E (USB) running and encounter the following problem:
The first one is detected and can be saved. The second one can be found ("Test function") delivers the correct value, but cannot be saved - ths usual error message appears ("two usb devices from the same.... cannot be ....").
does that help?
Offline ProBang2
« Reply #255 on: December 05, 2015, 04:15:51 am »
Hello.
Is this thread still of interest?
If yes: I´m now able to test with two meters.
Two UT-61E´s connected. Both with USB.
Meter1 set to show mV AC (some random stuff).
Works as expected.
Meter2 set to show Voltage of a 10V DC source.
In the "Add Meter" window it can be succesful tested.
The program can differ between the two meters and
displays the correct value.
(Look at the attached file "UDMM_testing_meter_2_Succes")
But Meter2 can´t be saved in the "Manage Meters"-part.
Suddenly can´t be differed between the two meters.
An error-message pops up.
(Look at the attached file "UDMM_saving_meter_2_Failure")
Pretty much the same as posted from zerobrain.
I´m curious if there is a solution.
Perhaps an identification with the Port# and Hub# ?
BTW: Simultanious measuring is possible.
First start the Uni-T-Software, then the UltraDMM.
(or vice versa, it doesn´t really matter.)
The first connected program will freeze the gauge and graph.
Re-connect it (the program, not the meter), that´s it.
BTW: This way it works with UltraDMM V1, too.
(Look at the attached file "UDMM_Uni-T_V4-01")
If there is more information needed, then feel free to ask.
I will answer asap.
Greetings,
Hartmut
« Last Edit: December 05, 2015, 04:47:11 am by ProBang2 »
Offline zerobrain
« Reply #256 on: December 06, 2015, 08:50:18 pm »
I´d like to followup on the last post.
I deel very sad, that the project seems to have stopped. The "two multimeter" thing would be so great for measuring batteries!!!
There is an additional bug - maybe due to localization. The comma is not displayed in the german setup, but saved correctly to the logfile. That´s a minor issue....
If the project is abondomed - maybe the sourceocde could be released to the community?
Offline Circlotron
« Reply #257 on: December 06, 2015, 11:23:45 pm »
Just saw this thread for the first time. Does anyone know if it runs okay on Wine on Linux?
Offline timofonic
  • Eternal Wannabe Geek
« Reply #258 on: December 09, 2015, 11:03:44 pm »
I would prefer if the author merges airtight and push all his talent into a team of a multiplatform suite for data acquisition of Testing/Measuring/Lab equipment. It would be amazing!
Offline Archie
  • Country: ee
« Reply #259 on: February 01, 2016, 04:41:21 pm »
In case someone is still reading this tread... :)
Victor VC86B meter could be used with UltraDMM even without code changes: you'll just have to use another data cable. In my case, I've replaced default USB HID cable with spare COM-port UNI-T one (type UT-D02) temporarily duct-taped to the output window. In UltraDMM settings, select "UNI-T UT-60E" and appropriate COM port: that's all.
Probably, I'll make separate DIY-cable to connect it via USB later.
Offline Hagis2k
« Reply #260 on: September 04, 2016, 05:06:35 am »
Hi there Tom long time since this thread been active...
How is the progress on this software do you plan on some release later on that
will work with my Voltcraft VC850 same as UniT Ut61e with the same cable.
/Peter
Offline Karel
« Reply #261 on: September 04, 2016, 07:05:27 am »
Next time, avoid that .net crap and use Qt:  https://www.qt.io/
Offline picitup
« Reply #262 on: December 10, 2016, 02:10:04 pm »
Is this still being developed?  I have some exceptions on my Windows 7 64 installation.  I can click on continue and it still works, but wondered if anyone is still maintaining the code?
Cheers
Steve
If you know what you're doing, then you're not learning anything.
Offline pascalbythree
« Reply #263 on: August 15, 2017, 06:36:51 pm »
Does anybody know weither my Victor 86E is ever going to work on my Windows 10  / Ubuntu 16.10 system?
Is the meter supported? Does anybody have a URL for the supported version.
The following users thanked this post: Royalgrass
Offline ProBang2
« Reply #264 on: August 19, 2017, 10:19:59 pm »
The Victor 86E uses the same chip as the Uni-T UT61E.
Perhaps it is worth a try...    :-//
Be aware: The first UltraDMM version needs an add-on
(somewhere hidden in this thread, not on the website)
for the data transfer via USB. Or try the "new" version
(hidden in this thread, too).
The following users thanked this post: 001
Offline 001
  • Country: aq
« Reply #265 on: October 27, 2017, 01:09:57 pm »
Sorry for necroposting
But what is actual state of UltraDMM project?
Offline Mr. Scram
  • Display aficionado
« Reply #266 on: October 27, 2017, 01:11:39 pm »
Show us how it's done!
Offline RES
« Reply #267 on: October 29, 2017, 12:21:45 pm »
UltraDMM 2.0.0.17498 runs on Windows 10 (x64). Virtual returns 0.000V. Have an old Metex DMM (M3850), won't respond on availables. M3850 runs on an older (9th Feb 2014) program called MScope (V1.08 build 146) via a Prolific USB to serial cable COM3 (ProlificSerial0) at 1200 bps.(single frames)
« Last Edit: October 29, 2017, 12:27:09 pm by RES »
Offline zerobrain
« Reply #268 on: November 09, 2020, 07:08:33 am »
Interesting!
Websites states: "Update: 2020-02-14 - Project is getting revived. Expect an update in the coming weeks"
I was hopeful, but couldnt find an update download. I consider this is really dead now.
« Last Edit: November 09, 2020, 08:00:31 am by zerobrain »
Offline BThunderW
« Reply #269 on: November 09, 2020, 02:35:06 pm »
It's not dead. We're working on the new version, but dev pace is slow due to covid related funding issues. We're still committed to it and will have an all new version out sooner rather than later.
The following users thanked this post: mcinque
Offline zerobrain
« Reply #270 on: November 09, 2020, 05:53:47 pm »
That would be great news!
As i wrote some years ago, i had serious issues with USB when using 2 UNI-Ts.
