I'm re-posting some information here from the other Rigol DS1052E thread since I didn't really know the answer before and this information is useful in its own right.
I came across solder with "no-clean" flux, and I didn't know what it was. How is it different from rosin or RA flux? Here's what I found out.
Traditional electrical solder flux is rosin, which is derived from a natural pine tree resin. This has two functions: firstly, it melts and flows over the joint, keeping oxygen out. Secondly it has a very mild cleaning action to dissolve oxide layers on the surfaces and allow the solder to wet and bond to them. Once the joint is cold, the rosin is inactive and does no harm, therefore it can be left in place without cleaning. However, if it is desired to make the board look nice, or if a conformal coating is to be applied, then the solder residues must be removed using a suitable solvent. Isopropyl alcohol alone will work, but other solvents like acetone may be mixed in to improve the cleaning power.
Plain rosin flux is designated as "R" on labels. Since rosin by itself has limited activity to dissolve oxides, some additives may be mixed with it to improve its effectiveness. This is known as activated flux, or "RA". There is also mildly activated flux, "RMA" which lies between R and RA types in activity. The residues of both RMA and RA flux are still safe to leave behind and do not have to be cleaned. However, they may be cleaned for the same reasons as above.
A third kind of flux is "no-clean" flux. This is in fact a specially purified or synthetic kind of rosin flux. It is rather similar in properties to RA or RMA flux and can be used the same way.
All of the rosin fluxes are delivered mixed with some solvent such as IPA to make them be pasty or liquid when cold. If you store the flux for a long time the solvent may evaporate and the flux may go hard.
A last kind of flux is "water soluble" flux. This stuff is a totally different thing from rosin fluxes. There are different types, but all are completely synthetic in nature, and have very aggressive cleaning power. Unlike rosin fluxes, the flux residues from water soluble flux are corrosive when cold and must be completely removed from the board after soldering. Usually this is done by washing with distilled water, maybe including a little detergent.
When soldering SMT parts the parts may have very narrow clearances with the board where flux residues can get trapped and not reached by the washing process. This is bad for reliability when using water soluble fluxes due to the corrosive nature of the flux residues. Therefore the general trend and the best recommendation is to avoid the use of water soluble fluxes and use the rosin type fluxes instead.
