First off, i'm new to the forum, hello everyone!
Anyway, I am currently building a laptop that uses an Realan LR1106-250W12VDC power supply. Thanks to the 11.8v ~ 12.5 volt variable input on the power supply I can power the entire computer off of a battery pack.
However, I am unsure as to how to balance charge five 6P battery packs in series. I know I can use an 18650 protection PCB but I have no idea how to wire the battery pack itself. Do I need resistors between cells? Diodes? How does this work?
Would it be easier or even feasable to put all of the batteries in parallel and use a boost converter?
Also, is it possible to integrate the battery so that windows detects the battery as part of the system?
