Author Topic: AC Chopper circuit  (Read 1866 times)
Offline nimit393@gmail.comTopic starter
AC Chopper circuit
« on: November 28, 2013, 07:09:07 am »
i am designing a AC chopper circuit -buck type.max 230AC 5A.
i am using IGBT
but can it be used for negative half cycle
or should the IGBT be connected to bridge rectifier so that in any case it sees a potential drop and at any moment at which i give i pulse, the igbt conduct the AC voltage.
suggest any other method if the above stated method isnt valid.
Offline Zero999
  • 0999
Re: AC Chopper circuit
« Reply #1 on: November 28, 2013, 02:09:25 pm »
Why do you think spamming the forum, by posting the same question 4 times, will improve the quality of the response?
