Author Topic: How much does LTZ 1000 weight?  (Read 1604 times)
Offline fonographTopic starter
  • Country: at
« on: March 05, 2018, 10:51:36 pm »
Do you have LTZ 1000 voltage reference that isnt soldered to something? Do you have decently accurate weight scale? If both of your answers are yes,then please,weight it and post your results in this thread!
Offline Zero999
  • 0999
Re: How much does LTZ 1000 weight?
« Reply #1 on: March 05, 2018, 11:40:19 pm »
Just one question: why?
Offline hugo
« Reply #2 on: March 06, 2018, 12:23:05 am »
He's probably trying to determine that the one he has is a genuine one or not ... ;)
  • Country: at
« Reply #3 on: March 07, 2018, 02:49:58 pm »
I am just curious.Problem I have with electronic components that often the datasheet contains everything imaginable except weight,I want to have total knowledge about LTZ1000 and I failed find any official weight.
Furthermore,I noticed weight of electronic components is often inaccurate,something that is 47g in one place,is 45 in another for example,so its hard to believe either of these numbers.if someone weighted it,thats information I would trust.
Offline m98
« Reply #4 on: March 07, 2018, 06:00:18 pm »
Send me an LTZ 1000 and I can give you the mass accurate down to 1mg.
Offline Mechatrommer
  • Country: my
  • reassessing directives...
« Reply #5 on: March 07, 2018, 06:43:56 pm »
if specification says 45g ±5g which one would you trust?
  • Country: at
« Reply #6 on: March 07, 2018, 09:05:53 pm »
There is big difference between weight specification of object that is manufactured in way that weight is highly consistent so the specification gives only one definitive number that would in 99.999% of weight measurement come exactly as specified and objects or items that have large random differences from item to item becose they are fundamentaly physicaly inconsistent so the weight is given in average value + plus minus random variation,semiconductor devices are not bananas ( atleast when it comes to mass ).
Offline ogden
  • Country: lv
« Reply #7 on: March 07, 2018, 09:43:51 pm »
Right. While you are weighing - could you please lick it as well? I would like to know it's taste.
The following users thanked this post: james_s
Offline splin
« Reply #8 on: March 07, 2018, 10:07:41 pm »
 LTZ1000CH .98g
[EDIT] Claimed accuracy is +/- .02g but neither of my two scales have been calibrated. FWIW they both gave exactly the same reading.
« Last Edit: March 07, 2018, 10:15:33 pm by splin »
The following users thanked this post: fonograph
  • Country: at
« Reply #9 on: March 07, 2018, 11:08:50 pm »
Thank you splin  <3  ^-^
