Does anyone know if there is a practical way to step down an AC voltage at a moderate current (say 250mA) without dissipating a lot of heat? More specifically, I have a 24V transformer I am looking to use in a junkbox parts power supply, and from it I would like to generate a 5V supply for some LED voltmeters. They draw something around 100mA each, but to power them with a 7805 running of the rectified 24V would be >20W disspation. Switching power supply is not an option really because of the noise and I don't want to have to order any new parts for this project. Would a capacitive or inductive divider work? I asked the Google and capacitive dividers disdn't come up with much other than theoreticcal type stuff, and there were some of the non-isolated usually driving LEDs type, but they seemed to be for low-current (<50mA). Does anyone know if there is a way to adapt the circuit to electrolytics or otherwise use an non-resistive voltage drop? JSYK Un fortunately there is not a center tap on the transformer. If need be I could use a little 9V transformer from an old radio, but I would prefer it to all run of the 24V transformer for simplicity. Thanks so much!
