Context: Frontpanel audio on PCs has two standards.
AC97 is the older standard. Audio is sent to the case front 3.5mm female jacks. If nothing is plugged in then the normally-closed switches send the audio back to the rear of the PC:
[attachimg=1]
(Source: Intel Front Panel IO connectivity design guide, Version 1.3)
HD audio is the newer standard that came out in 2004. It detects jack insertion using normally-open isolated switches (the small rectangles are plastic blocks/insulators).
[attachimg=2]
It's a pain to find 3.5mm female jacks with these HD-audio style isolated switches
It looks like 99% of the parts on LCSC use the AC97 style switch or something similar (normally-closed non-isolated).
Neither LCSC or Digikey have a way of filtering for just isolated-switch style jacks.
I had to open and review most of 100 datasheets to find one :(
(LCSC specific rant): Garbage datasheets for many of their jacks
Take the PJ-343K (https://www.lcsc.com/product-detail/_XKB-Connectivity-_C725881.html) which I tried to use:
[attachimg=5]
Above 100% of the information provided. Now try and make a footprint for it. I'll wait and see if you can spot what vital information is missing.
:scared:
Many of the other jacks I looked at have similar datasheet problems. XKB has no website that I could find or way of contacting them (possibly XKB is a westernised version of their name?). Some of the other companies' products I looked at are the same.
"Ah", but I thought, "I could use the footprint that LCSC provides for their EasyEDA product!"
[attachimg=4]
It turns out that this footprint is complete garbage. It's not even a mirror image or a single pin being off, most of them are completely wrong:
[attachimg=3]
So.. time to get my vernier calipers out, a cut 3.5mm male plug and a multimeter. Then respin the board. Because I think that will be less pain than looking for new HD audio jacks again.
Surely I'm doing something wrong here
It can't be this hard, can it?
Why is the market dominated by AC97-style switched parts? HD audio is a standard from 2004 and my current case has "HD audio" proudly printed in white on the plug -- or are they lying?
How do those front panel cables that let you choose between HD audio and AC97 work? They have two connectors on the end. These two standards shouldn't be electrically compatible as far as I can tell.
