The motor is a 6v mini pump motor. I supply 6v from the battery and 12 volts from the power supply separately.
Why do I need to divide by 10?
This noise is a very big issue for me, especially on the current side. I see some spikes at the beginning and after that, there is huge PWM noise.
I chose the L9110S motor driver. Thanks for the recommendation, I am also going to check those ICs.
One last question will be how can I give a constant voltage with battery to my motor? I just don't want while my motor is working the supply voltage is changing. Can I make it with Zener diode? Do you have any recommendations?
