Hi everybody,
sorry for the late response but we had a lot of trouble during testing so we have to undergo few twice with different tools.
At the end the main problem was that we took reference schematic which is for variable volatge IC, while fixed version was soldered.
Some of you spot the problem immediately but when we undergo troubleshooting purchasing a variable IC version and soldering on the board the issue remain (probably because our tool could not control the heat used during the soldering process)
My mistake was also not providing this forum with the BOM list, it will probably lead immediatly to the real problem and make it unquestionable.
Now we are going to change the configuration to support the fixed version and also we will place the input capacitors closer to the IC to reduce the noise.
My apologies again for the time you loose and my compliment for your efficiency in spotting the root cause almost at once.
My regards
Andrea Poma
