Welcome,
Guest
. Please
login
or
register
Did you miss your
activation email
1 Hour
1 Day
1 Week
1 Month
Forever
This topic
This board
Entire forum
Google
Bing
Home
Help
Search
About us
Links
Login
Register
Electronics
Projects, Designs, and Technical Stuff
Active Discharge circuit for large electrical motor
« previous
next »
Print
Search
Pages: [
1
Go Down
Author
Topic: Active Discharge circuit for large electrical motor (Read 3632 times)
eerocketman
Contributor
Country:
on:
July 08, 2017, 10:52:27 pm »
Hello,
I am currently working on an active discharge safety circuit for a very large electrical motor to trigger at the event of an emergency stop.
Can anyone advise me as to whether an IGBT or relay is the best option for the main discharge switch. I am dealing with around 100 Amps at a max voltage of up to 500V.
Logged
Circlotron
Super Contributor
Country:
Re: Active Discharge circuit for large electrical motor
Reply #1 on:
July 08, 2017, 11:28:42 pm »
What exactly do you want to discharge? A motor itself has nothing to discharge. Is it a large DC link capacitor in a variable speed drive?
Logged
jordanp123
Regular Contributor
Country:
Reply #2 on:
July 09, 2017, 12:03:33 am »
If your working with a large motor, then you may have access to antiquated or obsolete motor starter contactors, if so I would just use one of them, they are very robust, without looking anything up your looking at a NEMA 2 or so.
Logged
endevor100
Contributor
Country:
Reply #3 on:
July 09, 2017, 04:26:33 am »
If you're using a VFD or similar drive most of them have build in circuitry to do this. Brake resistor and regenerative resistor are terms I've seen on wiring diagrams. My understanding is that this is usually done with the IGBT both because of speed and cost.
You are taking about a load of 50kW. For your own safety you should consider that if you have to ask this question you might not be able to foresee all of the potential dangers to yourself and your equipment from your design. You have a lot of potential to do hard with this much power, be smart.
Logged
Print
Search
Pages: [
1
Go Up
« previous
next »
Electronics
Thanking...
EEVblog Main Site
EEVblog on Youtube
EEVblog on Twitter
EEVblog on Facebook
EEVblog on Odysee
