Over in the for sale section several forum members have picked up some of these high-def camera modules. I thought i'd start this thread so we can pool some resources together and see if we can get something meaningful out of the cameras.
https://www.eevblog.com/forum/buysellwanted/cameras-uk-burnley)/
The module is a HD video camera with upto 1080p30 output as '16bit YUV 4:2:2' which could mean several things TBH, i am going to hazard a guess it's something like bt.601 but
The maker is indicated as ACUTE Logic. A Japanese company they seem to have sold their camera module business to a Chinese company in 2011 so i guess these cameras predate that.
https://www.acutelogic.co.jp/en/http://www.leadcctv.net/PE1005S.htmlI have emailed both companies to see if we can get some documentation for them
Spec & Features:
1 1/2.5 inch 5.0 MegaPixel Progressive CMOS sensor
2 Full HD(1920x1080/30p)high resolution Color Camera Module
3 Video Output: supports 25 configurable format
4 Lens: 10X Optical Zoom, Approx.1 cm wide macro
5 Ultra-low-power design (≤800mw at 1080P/30 video output)
6 Dynamic digital image stabilization design (DIS)
7 3A Auto Control technology (AF, AE, AWB)
8 Defective pixel correction, Jitter correction, Backlight compensation
9 Day/Night: Auto
Parameter:
2 Full HD Resolution 1920×1080/30p
3 Lens: 10X Optical Zoom,Focus f=4.5 - 45.0mm, Aperture f1.8 - 2.2
4 Min illumination: 6 Lux / 0.35 Lux (High sensitivity mode / slow shutter)
5 Output: 16 bit YUV 4:2:2
6 Control Interface : I2C
7 Power supply: 2.8v, 4.0v
8 Power consumption: ≤800mw
9 Weight: 57g
10 Operating temperature: -10℃ ~ 60℃
11 Size: 30.9mm(W) x 34.7mm(H) x 61.8mm(D)
Functional:
1 Defective pixel correction / Jitter correction / Backlight compensation
2 Flicker Cancel: Auto/Off/Manual(50Hz/60Hz)
3 EV (-2EV~+2EV ), Resolution 1/3 EV
4 ISO: Auto/Manual(6 step)
5 Auto slow shutter: On/Off
6 The zoom morement direction and speed settings / read current zoom position
7 AWB: Auto/Daylight/Cloudy/Shade/Fluorescent light(white/normal/day)/Tungsten/Custom/Manual(specify x, y)
8 Sharpness: High/Mediun/Low
9 Noise Reduction: High/Mediun/Low/Off
10 WDR
