Hi all,
I've designed a circuit board with a Microchip switch (KSZ9897) going to a Ethernet-to-VDSL module (LX200V20).
The PHY ports between the two devices are connected using a transformerless connection as shown on Figure 4 in this application note (
http://ww1.microchip.com/downloads/en/AppNotes/ANLAN120-UNG.pdf).
By default with auto-negotiation & auto MDI-X enabled, the switch establishes a 10 Mbps, full-duplex link. I am expecting a 100 Mbps link since both devices are 100-BaseTX compatible and I've confirmed that by decoding the LCW (link-code-word) from their fast link pulses.
I have also tried a forced speed connection (disabling auto-negotiation). For 100 Mbps & Full-duplex, I can see some idle traffic on both RX and TX pairs, but the link does not come up. For 10 Mbps & Full-duplex, the link does come up and work. I have also tried disabling auto MDI-X, but that does not seem to change much either.
My question is what could be causing the link to only establish at 10 Mbps? I have attached some scope pics to help isolate the problem. The scopes are all from one of the RX/TX pairs between the switch and the AC coupling caps.
Scope 1) Forced 100 Mbps idle traffic
Scope 2) LCW from VDSL module (left burst), LCW from switch (right burst)
Scope 3) NLP (single burst of LCW) from VDSL module
Any help is appreciated!
